yet another frenchy (and a kind of build log)
Re: yet another frenchy
Postby Overnuts » Fri Mar 26, 2021 12:37 am
rjgimp wrote:Do you have PVC pipe readily available? If you heat it to between about 80-100 degrees C it becomes pliable so you can shape or bend it and when it returns to room temperature it retains the new shape. You could heat a section of pipe and reshape the profile from round to triangular to fit the interior shape of your box.
Yeah ! yes, I have some, this is a good idea, I'll try something like this.
thanks
-- this message can be strange due to my english skill, cause I'm french (and serious) --
my cargo build: http://www.tnttt.com/viewtopic.php?f=40&t=62745#p1135613
Overnuts
Images: 24
Postby Overnuts » Sat Mar 27, 2021 9:07 am
Yeah ! it's weekend, time to do things !
morning work :
cut and fold composite panel to build the lower part
164638
it seams I'm not to bad when I make itmeet the upper part :
164639
I need to get some " L " aluminium to glue edges
but thanks to "france patial enhanced lockdown for anybody don't really know why"© :?
shops are closed.
Anyway, I succeed to find sika auto/marine
for aluminium parts, I found some on second-hand website
I should get them in an hour ( and f**k government) :D
Overnuts
Images: 24
Postby Overnuts » Sun Mar 28, 2021 9:37 am
Going on with my build !
lower part is now made, trailer is not here at my home, I plan to go an evening this week to attach this.
164657
For 135° angle, I printed basic parts, 2 more are needed for each side, this is for tomorrow
164658
Front aluminium L band it there for style, panel is fold at this place :)
For this strip, I was lazy to make it in a single folded part... nevemind, it's a cargo trailer
Thanks to Sika AM, aluminium, pop rivet and "unperpendicular sides", rigidity is really good :D
Overnuts
Images: 24
Postby Overnuts » Thu Apr 08, 2021 11:22 am
Today, I went to the trailer garage,
just to drop my stuff on it to check things,
it looks good :)
164766 164767
For the moment, it is not attached, just putted on tongue
I will not attach it until I found a good hinge for upper part.
Overnuts
Images: 24
Postby Overnuts » Thu May 13, 2021 2:43 am
Hi !
Thanks to a few days off with a bit of sun, I succeed to build the front part of the trailer.
Almost as like on the plan :D inside gluing on frames is a bit dirty in upper part, due to sika auto-marine is long to dry :roll:
165199
No hurricane hinge but 4 stainless-steel hinge of 10cm glued and poped on frames.
For waterproofing, I'll add a kind of rubber tape over thes hinges, this should do the work.
This box will contains scuba suits, 100% waterproofing is not really required, anyway bottom part is neither waterproof, so water will leave.
More picture soon, I need to add some things to lock cover, and maybe cut a part of cover to reduce weight, right now, it overlaps 32cm on bottom one
Overnuts
Images: 24
