What did you do today
Re: What did you do today
Postby noseoil » Wed Feb 09, 2022 9:12 am
The rim is located on the axle now. Had to make a "few" adjustments with shims & bushings to center the rim, after trimming it to fit. The brake disc doesn't fit (the "standard" one for this 13" rim) due to pie-pan shape, offset & the narrow forks, so the new disc is larger in diameter. I need to mount the caliper closer to the hub, so I'm reworking the bracket by moving it inboard about 1/2" & adding a 0.30" thick shim to push it closer to the center-line of the 3mm thick disc. Next week it should be finished for this part of the build, once I get the new disc.
168286
137905
noseoil
Images: 670
Postby bobhenry » Fri Feb 11, 2022 6:38 am
DE CONSTRUCTION :oops:
Cutting out drywall and redoing my lighting in the "office". Tired of working in my shadow. I need to disconnect the computer. the TV, the DVD and CD player and move out the desk. All a big pain in the butt in such a small space. It may be put off until I can simply take the desk back outside. ( Come on spring )
After disassembling the ceiling fan completely and removing it to pull new wire to replace the one the squirrels chewed in half. I found out yesterday that the extra heavy extension cord that was in easy reach was what the fuzzy tailed tree rats actually chewed in two. So now I get to balance the 15 pound monster in one hand and use my other two ( :lol: ) to install the wire nuts and rehang the damn thing.
I also tested out my $12.50 yard sale surround sound 7 speaker system by hooking it up and attempting to use the AM FM tuner that is built into the unit to enjoy the new sound with a test. All I get is a 60 cycle hum with the radio faintly playing in the background. :x
https://video.search.yahoo.com/search/v ... tion=click
Postby twisted lines » Sun Feb 13, 2022 1:18 pm
All the sudden I want a fat tire mini bike again :roll:
Today I dug up a pattern profiler!
Thought I would share!
https://metalgeek.com/static/cope.pcgi
I need to make some tube fit tube at 90 and some other angles to join and weld together, I will be cutting by hand; hopefully not my hand.
Not responsible for; connected to, giving demonstration's, lesson's, or selling squat :stompspam:
Done with PDF Printed @ 100% Posted JPG @ 56% (Very Accurate / G code as well)
Good reuse of part's from a old Car wash!
I could use 8 please :lol:
Old Scrap's.jpg (40.26 KiB) Viewed 411 times
Racking up; And Rapin foam
twisted lines
Postby bdosborn » Mon Feb 14, 2022 4:38 pm
The van DC side is almost done, all the controllers are programmed and talking to each other. I still have some control wiring and wire management to do. Tomorrow I start working on the AC distribution, hopefully I can start charging the batteries by EOD.
Images: 806
Postby featherliteCT1 » Mon Feb 14, 2022 6:38 pm
bdosborn,
WoW! That looks great! :thumbsup:
What is the:
1. Gray square unit on the upper right?
2. Blue rectangular unit just to the left of the left charger controller?
3. Blue square unit just below the red cut off switch?
Thanks
featherliteCT1
Postby flboy » Mon Feb 14, 2022 8:35 pm
Wow.. very nicely done. Victron is the best stuff and your work looks so professional.
How many aH of batteries and watts of solar panels do you have?
Sent from my SM-N970U using Tapatalk
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby bdosborn » Mon Feb 14, 2022 10:39 pm
featherliteCT1 wrote:What is the:
MidNite Solar Baby Box Enclosure for 150V DC circuit breakers. I went with the real deal PV circuit breakers. They're not that expensive and you don't have to worry about what your panel voltage gets up to with them.
Victron battery protect for the DC/DC and PV charge controllers. The BMS I'm using will disconnect the chargers via the battery protect when it gets below freezing or if a cell voltage goes wacky or too high.
Victron battery protect to disconnect the DC loads from the battery if the voltage goes below 11.5V.
The Cerbo GX unit networks them over the internet so I can sit on the couch and see what the electrical system is doing. :beer:
Images: 806
Postby bdosborn » Mon Feb 14, 2022 10:49 pm
flboy wrote:How many aH of batteries and watts of solar panels do you have?
Those are 200 A-H CALB cells in 2P4S, so 400 A-H total. I'm going with 620W of Newpowa solar panels: two 210W and two 100W. The 210W will be in series and controlled by the Victron MPPT but the 100W panels will be in parallel and connected directly to the battery via a switch that's controlled by the BMS. I'm experimenting with a new type of PV controller that's supposed to be more efficient as it doesn't do any conversion of voltage. That's why I'm going with the Newpowa panels, they have a MPP voltage that's low enough to connect directly to the batteries. Hope it work. :worship:
Images: 806
Postby bdosborn » Wed Feb 16, 2022 6:59 pm
I bricked the Multiplus Compact inverter yesterday when it shut off in the middle of a firmware update.
Fixed it today. Thank goodness Victron has a firmware flashing tool that saved me! :P
Trust me, your inverter start up will not go well if you put a 30A fuse on the DC side instead of a 300A.
Images: 806
Postby Indiana Rambler » Thu Feb 17, 2022 8:19 am
So I couldn’t find a 1 1/4 router guide, and I ordered one months ago, only to be refunded my money, I decided to make one at work. Image
Indiana Rambler
Postby Staryder61 » Thu Feb 17, 2022 12:09 pm
bdosborn wrote:I bricked the Multiplus Compact inverter yesterday when it shut off in the middle of a firmware update.
Bruce, Great job on the system. :thumbsup: I envy people who have that much electrical talent.. sure glad I was able to go simple. :thinking:
I still haven't been able to finish my solar yet. Working on ideas for a rack for the top of the van. :NC
I've been watching for a log for your van.
Stay safe, David
Our CTC 6' X 12'
Staryder61
Images: 550
Postby bdosborn » Thu Feb 17, 2022 3:45 pm
Thanks David,I'll start a build log soon...
Images: 806
Postby Capebuild » Thu Feb 17, 2022 4:51 pm
Indiana Rambler wrote:So I couldn’t find a 1 1/4 router guide, and I ordered one months ago, only to be refunded my money, I decided to make one at work.
That looks pretty nice. nice threads.
really nice layout, Bruce. I get really inspired looking at other's Victron components. I'll have to wait to put my components into action.... but between you and lfhoward I'll have a lot of good reference material to learn from :)
Capebuild
Images: 130
Postby tony.latham » Thu Feb 17, 2022 8:03 pm
Now THAT was a good idea. Lathe I assume?
Postby Indiana Rambler » Fri Feb 18, 2022 5:39 am
Yes sir! I’ve poured over the internet and made a few calls to buy one, to no avail. Not sure why Porter Cable has discontinued this or why anyone else hasn’t reproduced it.
Indiana Rambler
