bdosborn wrote:Thanks! I saw 605w (620w capacity) from the PV panels yesterday so I'm pretty happy with the system.
Wow that's like 41 amps charging at 14.5 volts!!! Do you have 3, 207 watt solar panels up there?
lfhoward wrote:I have a 210 watt Hightec Solar panel on my trailer’s roof...
featherliteCT1 wrote:Andy, at Off Grid Garage, had a similar problem with some EVE cells and it turned out to be a bad connection at one of the bus bars, not sure if it was at the terminal or balance lead connection. In any event, he cleaned it up and the problem was fixed.
I am in the process of building my EVE 280Ah 12v 4s battery and am not sure if copper lugs and copper bus bars contacting the aluminum terminals will be a problem due to dissimilar metals. I do not plan on routinely pulling more than 20Ah at a time but could occasionally run a coffee pot and pull 70Ah for a few minutes.
I take it you are not worried about the copper on aluminum. Sure would make my build easier.
PS: I forgot to thank you for posting the Bussman’s Fuseology Handbook. The photo below from page 12 resonates with me.
fredryc wrote:Sorry for the off-topic... we're on our second Keurig coffee pot. Always use filtered water. Love the coffee, but, after 6 or so months they will only brew a half cup at a time. has read a lot of articles like these for solutions... Has anybody experienced this? Any recommendations?
Users browsing this forum: No registered users and 37 guests
