The photo down a bit in this post is a shot of the brace I make for standing the walls up. The brace holds the front, mid-point and galley end of the walls plumb while the glue (PLP) is setting on the floor attachment point. A simple set of braces will assure your foam doesn't need to be stressed after the glue dries as you pull the walls plumb for roof work.
Wall to floor seam exterior. I tape the canvas flaps up to keep them from getting in the way while I glue and anchor the wall. Then they will be glued down after the glue sets.
![Image](https://www.tnttt.com/gallery/image.php?album_id=3986&image_id=172201)
And wall to floor seam interior.
![Image](https://www.tnttt.com/gallery/image.php?album_id=3986&image_id=172200)
Better photos of the braces I use to keep the walls plumb. I have three across the top and one more in the window to door space to pull the wall straight.
![Image](https://www.tnttt.com/gallery/image.php?album_id=3986&image_id=172205)
![Image](https://www.tnttt.com/gallery/image.php?album_id=3986&image_id=172202)
![Image](https://www.tnttt.com/gallery/image.php?album_id=3986&image_id=172203)
And finally, the walls were skewed to the road side about a quarter of an inch so I rigged up a rope anchored by my wife's car to keep it straight while the glue sets. It will spring back so I will be putting in a square brace later before I start the headliner and roof materials. I made a brace to hold the wall straight even though the window frame will hold it straight. I want the window frame to mate with a straight wall for obvious reasons. As PMF dries it will pull the wall in different directions. Not a nightmare to remedy but you should watch for and adapt for that.
![Image](https://www.tnttt.com/gallery/image.php?album_id=3986&image_id=172204)
