Jst83 wrote:I'm about to start wireing my tear. I don't plan to have battery. I was wondering is there a real need for a fuse or breaker panel or can I direct wire it all to the cord to the campground electric. Hope this makes since
mikeschn wrote:If you can slip a gfci in between the campground power and your trailer, you don't need a fusebox/panel...
Steve_Cox wrote:How about a ground fault interrupter to plug into the campground power and then a power strip or two with a pop out breaker in the TD.
