Borrowed someones idea on poles supporting hatch............
Postby b.bodemer » Wed Sep 27, 2006 11:05 am
I saw this clasp from someones post and added a few more things to make it work for me. Since I have my counter tiled I did not want to have my supports resting there.
Here's what I came up with.
Middle is wrap around velcro
Bottom is a rubber furniture tip
Barb
b.bodemer
Images: 319
Postby dacrazyrn » Wed Sep 27, 2006 5:19 pm
You might go look for a closet rod holder made of wood for the bottom. Might keep it from slipping on windy days.
like this
dacrazyrn
Images: 74
Postby Claw » Wed Sep 27, 2006 5:37 pm
Looks good. :thumbsup:
I like the pin idea and the velcro should work well to keep it stable.
The hatch support is something that I would like to improve for my hatch. I haven't quite figure a good way to stow it.
JIM
JIM
Think about It!
Claw
Images: 120
Postby Gaston » Wed Sep 27, 2006 7:19 pm
you might try gas struts. I fooled around with a "pole support" till my better half knocked it loose and almost beaned herself. I bought a pair of 120' gas struts and mount brackets for around 30 bucks. A whole lot nicer than fooling with a support strut. They help me open the hatch, keep the hatch open and are out of the way when its open. ;)
The difficult we do now... the impossible takes a little longer
Gaston
Images: 98
Postby Scooter » Wed Sep 27, 2006 7:25 pm
Took apart a couple of rubber doorstops for mine....fit the dowels perfectly.
The RoadCamper the old teardrop
Scooter
Images: 69
Postby harldydodge1 » Wed Sep 27, 2006 8:31 pm
Great ideals. I've been looking for some pictures like this.
Thanks Keith
harldydodge1
Images: 62
Postby Claw » Wed Sep 27, 2006 8:55 pm
scooter
your support and stow is similar to what I have been working with but I have found that mine tend to slip loose and bang the counter and have used spring clamps to hold them in place during transit causing me to rest the hatch on my shoulder as I use two hands to loose and place into position. I will probably end up using gas struts but am going to the Camp Inn camp outt this weekend and am going to check out their design.
JIM
Think about It!
Claw
Images: 120
Postby sid » Wed Sep 27, 2006 9:01 pm
Here's the original post. Glad you could use the idea.
http://tnttt.com/viewtopic.php?t=10136
sid
sid n side
"If you're going through hell, keep going......" Winston Churchhill
Side by Side - completed October 2008
sid
Images: 194
Postby Claw » Wed Sep 27, 2006 9:16 pm
Sid I like that design, simple, low cost and practical!!! :applause: All the good thing associated with a TD
I put the hinge on the wrong end of my support :oops:
JIM
Think about It!
Claw
Images: 120
Postby WarPony » Wed Sep 27, 2006 9:49 pm
I'm the last one that should be giving advice on hatch supports because I have no galley but if I had a hatch held up by rods, I would make the bottom of each rod held secure to the floor/wall by some sort of mechanical device (chain, pin, bolt, etc.).
I have seen how alot of you guys/gals have toiled on the making of your hatch...... sometimes twice. It would pi$$ me off to no end if a big gust of wind blew the hatch up, one of the supports came undone and it came down on the remaining leg. I can only imagine what THAT would do to a galley hinge and the spar underneath, let alone the integrity of the hatch:thumbdown: .
Remember: The amount of "force" by air and water is multiplied 4X by whatever speed air/water is moving.
10 MPH = 40 LBS of force
20 MPH = 80 LBS of force
30 MPH = 120 LBS of force
Now, I don't want to get into a big flame war with any engineers. I just wanted to make aware the considerations into using legs to hold up the hatch.
WarPony
Images: 289
Re: Borrowed someones idea on poles supporting hatch........
Postby GHOSTSSX » Wed Sep 27, 2006 11:18 pm
b.bodemer wrote:I saw this clasp from someones post and added a few more things to make it work for me. Since I have my counter tiled I did not want to have my supports resting there.
Barb
Did you use TORX screws everywhere??
Very Nice!! Next to Duct tape, VELCRO is very versatile!
CHUCK
GHOSTSSX
Images: 35
Users browsing this forum: Bing [Bot] and 8 guests
