Fantastic Fan Question
Anything electric, AC or DC
Postby Mary K » Thu Mar 15, 2007 10:36 am
Laredo wrote:If you haven't started cutting yet, buy some wide blue masking tape.
Drill your holes, put TAPE where your lines will go, mark on top of the tape, and you can cut it with lots less risk of tearout.
Hey!!! Good Idea!!! :thumbsup: :thumbsup: :thumbsup: And, No, I haven't Yet.
Yall keepem comming!!!! :twisted: :twisted: :twisted:
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby diverguy » Mon Mar 19, 2007 9:43 am
mk, one suggestion, drill a hole in the frame for the wire and put it through and have a good length hanging. beore you skin the top, pull it back through to where it is just inside the hole so you can grab it with some needle nose plyers. after you cut the skin you can pull it back through. i made the mistake of leaving my wires hanging and when i cut the skin out with my saw i cut the wire off. darwin award. luckly i grabed the end with some pliers and it pulled out a couple of inches. so i had enough to hook up. saved again.
diverguy
Images: 192
Postby Duane King » Sat Mar 24, 2007 4:03 pm
I wished I had caught this thread a while ago. I framed my vent opening at 14" square. The woodworking is perfect. Now I've got to cut the opening bigger! And I'm all done installing the ceiling! I try to be amazing, but most of the time, it doesn't work out.
:x :x :x
Aaaarrrrgggg!!!!
Duane King
<img src="http://www.mikenchell.com/images/roadhouse.jpg" >
Duane King
Images: 98
Postby madjack » Sat Mar 24, 2007 5:15 pm
Duane, a possible save for your ceiling...first, do nothing until you have the fan in hand to actually check out clearances...it may be that you can wiggle it into place with the biggest problem being clearance for the wiring...the inside trim ring fits inside the fan housing(I think) which means the ceiling could remain untouched just opening up the framing above it...a router with a long shank bit could be your best friend here...at worst, the flange on the trim piece is fairly wide and should hide any booboos...
madjack 8)
Postby asianflava » Sat Mar 24, 2007 9:30 pm
You could run a router along it using an 1/8 rabit bit. If your roof isn't too thick, or if you can find a bit long enough, you can run a top bearing pattern bit to remove the rest.
asianflava
Postby critter » Sun Mar 25, 2007 2:59 pm
Hey Mary,
Dont forget ebay...the best palce to buy fans i bought my fantastic fan for next to nothing and it looked and worked like new.It was taken out of a camper that was only a year old and was wrecked. :thumbsup:
critter
critter
critter
Images: 54
Postby Mary K » Sun Mar 25, 2007 11:39 pm
critter wrote:Hey Mary,
:thumbsup: All my parts searches start at ebay!!!
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby kayakrguy » Fri Mar 30, 2007 7:06 pm
Mary...good advice all around so far. I put in the frame first, skinned the inside ceiling, drilled a hole in the ceiling and routed out a hole in ceiling....came in handy to hang a light through when working inside!
After running wire in the roof (mine had driver side fron wiring hookup) I then lleft the wire hanging through a hole in frame.
Skinned roof, routed the vent hole and slipped the fan in and voila! Hole too tight to fit both fan and wire in the hole. I ended up chileling out a recess in one framing board so the wire wouldn't bind the fan when I tired to insert it.
Moral of the story....don't, don't, dont create a 14" square hole...!
:? 8) Jim
A disposition to preserve, and an ability to improve, taken together, would be my standard of a statesman...
But what is liberty without wisdom, and without virtue? It is the greatest of all possible evils; for it is folly, vice, and madness, without tuition or restraint.
Edmund Burke
kayakrguy
Images: 195
Postby toypusher » Fri Mar 30, 2007 7:42 pm
kayakrguy wrote:.......................
:? 8) Jim
There is plenty of trim to make the opening 14 1/2 X 14 1/2 , to don't make it more difficult than it has to be!! :)
toypusher
Images: 324
Return to Electrical Secrets
