Slides for The Cooler
Postby Classic Finn » Sun May 06, 2007 6:13 pm
As long as Im working in the Galley - I thought I should find out and see which way is the proper way of installing the slides for the cooler.
I do have a hunch but thought Id make sure which way these things should install..this is like learning a new language.. :lol: :lol: :lol:
Here are a couple of pics I took this evening or should I say morning..showing the slides flat instead of on their sides..Is this the correct way or should they be on the sides instead?
or should they be like this?
Classic Finn
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Phil & Ningning » Sun May 06, 2007 7:58 pm
Most drawer slides are designed to operate in a vertical position. If you lay them flat they simply will not carry the weight of a cooler.
Phil & Ningning
Images: 65
Postby Miriam C. » Sun May 06, 2007 8:33 pm
Heikki, I have slides like that and they go vertical on the side of a drawer, unless yours say specifically they are bottom mount. :thumbsup:
Could you hurry up so I can borrow your idea's. ;) Looks like you have little tabs for the screws too.
Postby Dale M. » Sun May 06, 2007 8:34 pm
Actually you have to back track and find out what the slides were designed to do...... There is two styles, some mount vertically and some horizontal... The horizontal types are typically used UNDER pullout shelving in pots & pans area under kitchen counters. The other style mount on sides of drawers to cabinet walls...
Try searching product name and model number to see design criteria...
My "guess" by the ball bearing design and the bent out tabs, they mount vertically like in last picture...
Dale
Dale M.
Images: 18
Postby Denny Unfried » Sun May 06, 2007 9:02 pm
The type of slides that I used are full extension #100 and mount on the sides.
aka - "Uncle Denny"
<img src="http://www.uncledennyscorner.com/teardrop/photos/Linux.gif">
Denny Unfried
sprint car builder/racer & all that jazz
Postby Classic Finn » Mon May 07, 2007 3:03 am
Denny Unfried wrote:The type of slides that I used are full extension #100 and mount on the sides.
Wow.. Is that the famous Uncle Denny chiming in? :thumbsup: :thumbsup: It is great to hear from you.. Ok I know now they are to be installed vertically.. :? :?
Thanks for teaching this ol fart somthing new.. :lol: :lol:
Classic Finn
Classic Finn
Images: 146
Postby Classic Finn » Mon May 07, 2007 3:04 am
Phil & Ningning wrote:Most drawer slides are designed to operate in a vertical position. If you lay them flat they simply will not carry the weight of a cooler.
Thanks I learned sumthin new in my ol age.. :oops: :oops:
Best regards
Classic Finn :thumbsup:
Classic Finn
Images: 146
Postby Classic Finn » Mon May 07, 2007 3:07 am
Miriam C. wrote:Heikki, I have slides like that and they go vertical on the side of a drawer, unless yours say specifically they are bottom mount. :thumbsup:
Hi Auntie M.
Yup they have the lil tabs on them.. so I need to have one installed into the wall there and then make a side brace for the other side..
:shock: :shock: Im hurrying... about as fast as a turtle on land.. :D :D
going out to do some cutting and gluing and... :lol:
Ohh but not without a cup of coffee ;) :thumbsup: On the Road Again..sorry I meant in the Tear Again..Going places where Ive never been.. :lol: :lol:
Classic Finn ;)
Classic Finn
Images: 146
Postby Miriam C. » Mon May 07, 2007 8:59 am
:M " The thing I love is going campin with my friends :M :thumbsup:
Denny's sliders don't have the tabs. That probably means you bottom mount the tabs and it will line up you slider. Mine is like Denny's and I have to measure up.
Let us know how it worked when you wake. ;)
