TOM-
I thought about the same thing. What kind of material will you use as the underlayment and how much and what type of material will you use for the fiberglass
Thanks
BILL
SteveH wrote:Tom,
I researched and considered using Filon, but because of the sizes of pieces I needed, there was going to be so much waste that the cost was too high.
BILLYL wrote:TOM-
Thanks
BILL
kuffelcreek wrote:
Kevin Hauser
Kuffel Creek Press
TomS wrote:This project will be the first time that I'll work with fiberglass and epoxy.
<snip>
Steve Wolverton has a lots of experience working with the stuff.
angib wrote:If you don't mind the cloth weave showing, plus the occasional epoxy drip or run that you missed, then it's no problem. But if you are expecting to get anywhere near an auto body standard in less than many full days of work, filling and sanding (and then filling and sanding some more), you may be disappointed......
Just my twopennyworth (currently down from its high of 3.9 cents US to 3.7).
