I was at Lowes the other day and found an article in Fine Woodworking that
should be of interest to all of us builders.
Over the years there has been a lot of discussion about various glues and
their attributes. To date scientific testing has been in short supply but Fine
Woodworking magazine has provided the first that I have found. In the
most recent issue (August '07) F.W. tested six different glues of which four
are of interest to us.
Here is a link to the article on theFine Woodworking website:
How Strong Is Your Glue?
We take six types to the breaking point, shattering some common wisdom in the process
by Mark Schofield
View PDF
Membership Required
Glue is so essential to woodworking that there are dozens of types and
masses of competing brands. There is also a lot of "conventional wisdom."
To see if that conventional wisdom has any basis, Fine Woodworking ran a
test on six common types of woodworking glue -- a traditional yellow glue
(PVA), a Type I waterproof PVA, a liquid hide glue, a hot hide glue, a
slow-set epoxy, and a polyurethane.
We used each glue on tight, snug, and loose bridle joints in maple, oak,
and ipe, sending the glued joints to the Department of Materials Science
and Engineering at Case Western Reserve University for testing. Much of
what we learned was surprising. Watch a video demonstration of the
testing process by following the companion link below.
From Fine Woodworking #192
![Image](http://www.taunton.com/finewoodworking/uploadedImages/Fine_Woodworking_Network/Image_Resources/Magazine/192/011192036_sprd.jpg)
Membership signuP for the mag to get access to online results. Good if your going to buy the mag anyway?
View PDF
Membership Required
http://www.taunton.com/finewoodworking/ ... 192036.pdf
Video presentation to show how tech they were in the tests.
http://www.taunton.com/finewoodworking/ ... x?id=28853
Of course they don't give the results on the video, so I want to summarize them.
Results*
Type 1 PVA (Titebond III) - strongest
Slow set epoxy (System Three) - 99%
PVA (Elmer's carpenter's) - 95%
Polyurethane (Gorilla Glue) - 58%
The most surprising finding to me is that the Polyurethane glue is
much weaker than any of the yellow glues or the epoxy!
If you want all of the details you should grab a copy of the magazine and
or sign up on line for the magazine and get the results immediately.
Joanne
