Ira wrote:Vintage, if you go with the cheaper folding one with 12" wheels (I did), there are some minor modifications you make to it when assembling. A lot of us did this, per the Cubby plans:
Basically, there are two pieces of steel intended to be used as cross members. Instead, we inserted those pieces in the channels where the side rails meet on each side to beef it up in the middle. (The sides are composed of TWO pieces, designed to fold in the middle.)
So now it don't fold, but now you're a cross-member short for the center--so you put lumber there instead.
Ira, or someone else, could you sketch this out?
