madjack wrote:I would predrill all screw holes and fill 'em with glue...the glue will seal and harden the wood, giving the screw much better "bite".........
goldcoop wrote:madjack wrote:I would predrill all screw holes and fill 'em with glue...the glue will seal and harden the wood, giving the screw much better "bite".........
MJ-
I thought that process ONLY worked in conjunction with the Acme #2 Board Stretcher![]()
Cheers,
Coop
Jiminsav wrote:you could drill ½ flush bottom holes an inch in from the edge almost all the way through and insert some hardwood dowels in the holes and screw into them.
40deluxecoupe wrote:Jiminsav wrote:you could drill ½ flush bottom holes an inch in from the edge almost all the way through and insert some hardwood dowels in the holes and screw into them.
Yep, that is an idea that crossed my mind, have to work out how to drill a hole with out going right through as the interior finish ply is already fitted and I dont want to go through that. Maybe if I get another 1/2 inch spade bit and grind the point off it and start with a normal spade bit but bottom out the hole with the ground off one? What do you reckon? I also thought about using aluminum rod instead of dowell, and drill and tap into it so I could use stainless metal thread bolts instead of screws. You can see I am a metal man at heart.
40deluxecoupe wrote:Geez that was quick, dont you blokes sleep????
Thx for the ideas, I am on a ship off the east coast of India and building mt T/D in my mind, Im ready to fix the doors and need ideas.
