Keep the Beer Cold!
Keep the Beer Cold!
Postby Hillbilly Gene » Thu Jan 10, 2008 1:45 pm
I was thinking about building a super-insulated icebox, and letting the drip-water drain into a pan under the icebox. This icebox will be for my dry food (cheese, lettuce, fruit, eggs, etc) that I don’t want waterlogged. :( Anyway, in that drip pan I was going to store some 12-oz cans and cool them with the drip-water. The lift-off top is for adding an ice block. I was going to have a front door to gain access to my cheesy-cheese and beer.
Hillbilly engineering at its best!
1 BTU (British Thermal Unit) is the amount of heat that is required to raise the temperature of 1 pound of water through 1 degree Fahrenheit. This is heat added, but it works both ways: 1 BTU of heat needs to be removed to lower 1 pound of water through 1 degree Fahrenheit. This is also the definition for the Specific Heat of Water, which = 1 (no units).
So what? :scratchthinking: Well…. one gallon of water weighs 8.333 pounds at 65 degrees F. At 8 pints to a gallon, one pint (16 fluid ounces) weighs 1.04125 pounds. A 12-oz drink weighs 1.04125 x 0.75 = 0.78 pounds. The 0.75 is three-quarters of 16 fluid ounces, or 12 fluid ounces.
In this case, 16 fluid ounces does NOT equal a pound, but it’s close. It’s easy to get confused between fluid ounces and Avoirdupois ounces (where 16 ounces really equals a pound). :? Might be why most of the rest of the world uses the metric system. :D Or they’re not up to the challenge. :lol: 8)
In any event, it takes a 12-oz beverage (at 70 degrees F) 38 x 0.78 BTU removed to cool to 32 degrees F. Or 29.64 BTUs total removal. The 38 represents going from 70 to 32 degrees. The 0.78 is the BTU removal requirement (per pound) of the 12-oz drink.
A six-pack needs 177.84 BTU’s removed (6 x 29.64 BTU per can). Ya gotta love the Brits for that unit. If you’re handed a 12-oz beverage that’s at 32 degrees F, you’re gittin’ a cold one! :applause: :beer:
Heat of fusion: The number of calories of heat energy required to melt one gram of any substance without producing any change in its temperature is called the heat of fusion of that substance. Well…. yeah!… and how can something be heated without raising its temperature? :roll: :question: Voodoo science? :shock: Nope; by melting ice at 32 degrees that’s floating in water at 32 degrees; the water temperature won’t go up until the ice has completely melted. :yes:
The heat of fusion of ICE is 80. It takes 80 calories to melt one gram of 0-degree Celsius Ice into 0-degree Celsius water. Reverse: It takes 80 calories to freeze 1 gram of 0-degree Celsius water into 0-degree Celsius ice. That’s 80 times the water’s specific heat. Yawn… :SH
O.K. Back to BTU’s :twisted:
Since 252 Calories = 1 BTU, 1 gram of ice needs 80 calories/252 BTU’s per calorie to melt; the calories drop out of the equation, leaving 0.3175 BTU’s. One pound [Avoirdupois, where 1 lb =16 oz.] equals 453.59 grams. So 1 pound of 32-degree F ice needs 144 BTU’s added to melt into 32-degree F water. (0.3175 BTU’s x 453.59 grams per pound)
My calculator’s gettin’ hot. :fan: Now taking the 8.333 pounds for one gallon of frozen water, it requires 1,199.52 BTU’s added to melt that gallon of ice into one gallon of water at 32-degrees F. (144 BTU’s per pound x 8.333 pounds) This is the heat of fusion at work. Once the ice has completely melted, I still have 8.333 pounds of 32-degree water with specific heat remaining.
Relentlessly continuing the math: 1,999.52 BTU’s divided by 29.64 BTU’s per 12-oz bev equals 67.46 cans of beer cooled. The specific heat of the remaining 32-deg F melt-water is 8.333 pounds x 1 BTU per pound = 8.333 BTU.
Hmmm… :thinking: Can I use that remaining specific heat to cool another 0.56 can of Beer, making an even 68 cans cool? I’m so frugal. 8) The math says 0.56 (56%) remaining liquid x 0.78 pounds (remember, one 12-oz drink = 0.78 lbs) equal 0.4368 BTU per-degree F the can needs to lose. I bang my calculator to find 8.333 BTU specific heat available divided by 0.4368 BTU per-degree drop equals (BTU’s cancel out of the equation) 19.07 degrees drop. The 0.56 can of liquid started at 70 degrees F, so it will only drop 70-19.07 degrees F, or down to 50.93 degrees. Yikes! :frightened: Not for me. :thumbdown: Dump it on the hot brats and kraut. :Flippin Burger:
Darn. :fb . It would take the specific heat in at least 4 gallons of melt-water to properly cool one can. I also ignored the can heat itself, and the heat of sugar and other non-water contents of the can. As you might have noticed, no time was involved with cooling the beer, just BTU transfer. :whistle: Even so, I find the drip-water drain pan not worth the space or time to build, and that’s with perfect insulation (no heat loss or gain). As soon as I find that perfect insulation I will also be able to cool 67 full cans of beer with one gallon of ice. In the meantime, I’ll keep my beer submerged in the water of melting ice inside a good cooler. Beer-can marinade, so to speak. :lol: 8)
What else have I learned? :question:
1. Keep the melt-water (Specific heat) with the ice cubes (Heat of fusion) together at all times. It keeps the whole combination at 32 F until the ice is gone.
2. One six-pack needs to lose about 180 BTU to cool from 70 to 32 F. (So don’t buy warm beer! Duh! Even Hillbillies know bettern’ that. ) :rofl:
3. One gallon of ice (Milk Jug) should cool about 1,200 BTU.
4. One pound of ice has about a 145 total BTU cooling capacity.
5. The Specific Heat of Ice (below 32 F) = 0.504. 1 degree F rise = 0.504 BTU per pound. Not much heat suckin’ ability there. Specific Heat of Water = 1.
6. When all the BTU’s are gone from the ice, you need to drink the beer fast; it’s getting warm!! The ice should really outlast the beer in a perfect world. :angel: :beer:
7. Insulation is worth its weight in gold.
8. Math might save time and money. Sometimes. Maybe? :?
9. Cold Beer! Ya!….das iz goot bier! :beer:
Cheers!
Hillbilly Gene
Gene
The gene pool could use some chlorine…
Hillbilly Gene
Postby bobhenry » Thu Jan 10, 2008 2:06 pm
Holy Stromboli are you and Andrew hanging out together !!! :o
Postby Wolffarmer » Thu Jan 10, 2008 2:12 pm
After reading that I need need that six pack of beer. :D
Wolffarmer
Images: 309
Postby ATXKJ » Thu Jan 10, 2008 2:12 pm
What if your adiabatic assumption does not hold?
Add a nice convection flow to a 90F summer day and see how much you can cool.
Foam should be about 16-20 mW/MC
(personally, I prefer empirical testing when possible – Shiner Bock – bottles not cans)
David
ATXKJ
Postby prohandyman » Thu Jan 10, 2008 2:16 pm
Is that like the theory of relativity, or something? :lol: :lol:
Anyway, I am going to insulate the cabinet area inside of which the cooler slides into, thus providing a cooler climate for the cooler!
Dan
prohandyman
Images: 785
Postby tonyj » Thu Jan 10, 2008 3:15 pm
I am perfectly willing to either go to the store and buy more ice so I don't have to do the MATH!, or, quickly drink all the beer before it gets too warm at which time I can't even attempt to do the math.
Prost!
tony
tonyj
Images: 160
Your calculations may be accurate, however..................
Postby eamarquardt » Thu Jan 10, 2008 5:07 pm
Yer right, the cooling power of water at 32f is not nearly the same as ice at 32f due to the latent heat of fusion. But, I believe that stuff sloshing around in water is not good (personal experience with icebox on sailboat). So you put a drain in the bottom of the icebox (3/8 or so pipe or tubing) with a loop in it to form a water trap. That way the water can escape the icebox (where it does an excellent job (25 time better than air) of conducting the cold you are trying to perserve to the walls of the icebox) but the cold air at the bottom of the icebox can't. Put more simply, the less water in the icebox, the longer your ice will last (proven low tech on boat iceboxes). Water in the bottom of an icebox is baaaaaaaaaaaaaaad.
You now have cold water dripping out of your icebox. Granted it's not as good as ice but you can still use it to absorb some heat. If the outside temp is 90f and you mix an equal amout of beer (in the can) and water, I bet the can will get close to 60f or so. Not great, but better than 90f. Now you have a choice. You can drink cool beer versus hot beer or you can put the precooled beer in yer icebox and use less than half the ice you would have used earlier to cool it.
I would install a drain with a trap, route the tube under the tear, buy a cheap cooler that will hold a six pack and slide under the tear, drill a hole in the top of the cooler and let the cold water flow into the cooler to precool the beer (other liquids may or may not require the same treatment as a persons beer). Because you want a drain anyway, the extra time to route it with a loop for a trap is negliable. A cheap cooler can be had for less than ten bucks (I'm guessing). So there you have it.
Keeping the beer sloshing around in the bottom of the icebox with lots of water is bad. Better to put the beer on top of the ice and let the water drain out. Also the fewer and the smaller the openings into the icebox the better.
Hope this helps.
Cheers,
Gus
eamarquardt
Images: 150
Postby Unkl Ron » Thu Jan 10, 2008 5:18 pm
After filling up your cooler with ice, if you put some water in the cooler and then add about a handful or 2 of salt, the actual water temperature will approach 29-28 deg. (without freezing) and keep the beer and ice colder longer. Beer in Ice ONLY takes about 30 minutes to get initally cold, but by adding the salt - the beer gets to drinkable temp. in about 4-5 minutes. Works the same way the ole Ice Cream Maker works...
Unkl Ron
Postby jeep_bluetj » Thu Jan 10, 2008 5:23 pm
mmmmmm beeeeeer.....
I've got to go camping soon.
I just put the beer in ice. Then I drink it. Don't need no fancy calculatin for me... :lol:
-- Jeff --
jeep_bluetj
Postby bobhenry » Thu Jan 10, 2008 7:12 pm
prohandyman wrote:Is that like the theory of relativity, or something? :lol: :lol:
A cooler cooler How cool is that !!!!! :lol:
Postby prohandyman » Thu Jan 10, 2008 7:51 pm
Kevin or someone did a cooler test a while back, and several people agreed that covering the cooler with a reflective sheet insulation helped the cooler. And as side the cabinet I might also cover the cooler, I thought that if I coat the "chamber" the cooler resides in would also help. One person even coated the inside of the cooler with the same material (Refletex I think)
Dan
prohandyman
Images: 785
Postby Miriam C. » Thu Jan 10, 2008 8:44 pm
:lol: Yeah I almost read it all. :?
So never mind the math. Set your fridge to supper low (colder) and get that beer reallllllyyyyyyy cold. No need to wait to get it cold. Pop the top on one and maintain the rest.
NEVER BUY HOT BEER :thumbsup: Or pop
Postby Mark72 » Thu Jan 10, 2008 8:56 pm
My head hurts. :? Where did I put my beer?
Mark72
Images: 127
Postby Hillbilly Gene » Thu Jan 10, 2008 8:57 pm
:lol: :lol: Yep…..I’ll have to admit that maybe that math was a little over the top. :D 8)
But it you hadn’t gotten too glassy-eyed by the end, you’ll see that it allowed me to come to a sound decision, which was NOT to build in a beer-stash tray. Time well spent.
I once read that someone, with a calculator, proved a bumblebee couldn’t fly. Heck… I proved THAT when I smacked the little bugger with mine. :thumbsup:
I tried the E=MC(squared) thang, but the M and C keys don’t work on my calculator.
BTW. Cool Cold Cooler in your teardrop! Is that Ice Cubes melting in your sink? 8)
eamarquardt wrote:I would install a drain with a trap, route the tube under the tear, buy a cheap cooler that will hold a six pack and slide under the tear, drill a hole in the top of the cooler and let the cold water flow into the cooler to precool the beer (other liquids may or may not require the same treatment as a persons beer).
Thanks for the suggestion. I don’t want to waste that drip-water if I can capture it. Rather than dilute my beer, I can dilute that clear stuff that’s in quart jars. You know, that moonbeam... or something like that. :whistle::picklejuice:
Unkl Ron wrote:After filling up your cooler with ice, if you put some water in the cooler and then add about a handful or 2 of salt, the actual water temperature will approach 29-28 deg. (without freezing) and keep the beer and ice colder longer. Beer in Ice ONLY takes about 30 minutes to get initally cold, but by adding the salt - the beer gets to drinkable temp. in about 4-5 minutes. Works the same way the ole Ice Cream Maker works...
Yep…I thought of that….I won’t go into the math why it works, though…. :no: I’m designing my dry foodstuff icebox and wanted to use the drip-water to pre-cool a few beers. The saltwater trick will work in my dedicated beer cooler. The first couple of sips may have slightly salty margarita overtones, but I’ll just stick out my pinky and pretend the beer was a good year. :SG
Hi Aunti M!
Hillbilly Gene :scratchthinking:
Gene
Hillbilly Gene
Postby Dooner » Thu Jan 10, 2008 10:53 pm
:drofl: :drofl: :drofl: :drofl: :drofl: :drofl: :drofl: :drofl: :drofl: :drofl: :drofl: :drofl: :tipsy:
tonyj wrote:I am perfectly willing to either go to the store and buy more ice so I don't have to do the MATH!, or, quickly drink all the beer before it gets too warm at which time I can't even attempt to do the math.
Prost!
Dooner.
TED NUGENT FOR PRESIDENT!
Dooner
Images: 69
