Question on Molding
Postby madjack » Thu Feb 14, 2008 11:51 pm
...trim one side of the "L" down to 1/4" first and then anneal and bend...a rubber mallet, a hardwood dolly and an extra pair of hands can do wonders in this situation!!!!!!!!!!!
madjack 8)
Re: bending L shaped aluminum
Postby eamarquardt » Thu Feb 14, 2008 11:53 pm
[quote="GageSounds like a lot of extra work to me. Is it really time & cost effective?[/quote]
A friend of my brother's saw my garage (see album) and asked "do the tools pay for themselves". My reply: "no, but neither does a Winnebago".
Building your own is not always about being cost effective. It's about doing exactly what you want and achieving the results you seek.
Cheers,
Gus
eamarquardt
Images: 150
Postby len19070 » Fri Feb 15, 2008 4:53 am
Toytaco2 wrote:I'll soon need to make some molding decisions on my own build. I'm going to really show my ignorance here and ask, exactly where would you use this "RV insert corner molding" and how does it work. What is the insert?
ImageNo molding
ImageMolding with out insert
ImageFinished, Molding with insert
Happy Trails
Len
len19070
Images: 24
Postby bobhenry » Fri Feb 15, 2008 5:49 am
kinda remindes me of someone ???????????
:thinking:
The Michelin man yeah that's it
Postby Willys11 » Sat Feb 16, 2008 12:38 am
I got the harbor freight stretcher and shrinker.......Wow.....couple of practice tries and I was able to get my side profile radius right on the money. couple more tries and I was able to make about a 6 inch diameter circle pretty evenly radiused. I'm not overly excited about the grab marks on the aluminum where the shrinking process occurs, but a quick hand sand with a foam sanding block and it was way better.....not great, but better. After seeing Lens molding and how it looks after the insert is installed....Pretty tough to argue with the professional looking results that nets. I have always preferred building it myself if possible, makes me feel good. This will be a tough decision.
Thanks again for all the inputs. I went from not having a clue, to having a number of options to choose from. I've said if before.......I'll say it again.....
I love this group.
John
Willys11
Yup
Postby eamarquardt » Sat Feb 16, 2008 1:36 pm
John, I think you have it. Explore new horizons, push the envelope, and do exaclty what you want.
I think with a flat sanding block with a thin felt or rubber cushion, you can take all of the "grab" marks out of the flange of the bent aluminum. I really like the result with no buckling.
Cheers,
Gus
eamarquardt
Images: 150
Postby Mark McD » Thu Feb 21, 2008 8:34 am
I had problems bending annealed home depot aluminum moulding also. The first problem was the grade. It's very hard as far as aluminum goes because it's a cheap,brittle alloy. My second problem - I was attempting to bend the 3/4" moulding. It's way too wide to bend without kinking.I was able to find 1/2" aircraft grade moulding that is butter soft and very reasonably priced. URL below. Also, this company carries 5052 aluminum sheeting in any length, cut to order. And they are a great "mom and pop" company that will go above and beyond to help thier customers. Also, they carry a moulding called "bulb angle" that makes an excellent drip edge.
Cheers,
Mark
www.airpartsinc.com
I like turtles
Mark
I don't feel tardy
Mark McD
Images: 63
Postby klattin3 » Sun Feb 24, 2008 10:13 pm
I got a great deal on roof edge molding this week from a RV salvage yard. I bought 20 feet ot it , (10 feet each side) for $8.00 a stick and he cut it down from 14 feet and he has 4 more out in the yard. :thumbsup: I made 6 calls before i found him but i saved 30+ bucks
Its better to not have awards and deserve them than it is to have awards and not deserve them.
-Not Me-
klattin3
Images: 16
Users browsing this forum: Google [Bot] and 4 guests
