Newbie with a couple of ????'s
Postby klattin3 » Wed Feb 13, 2008 10:05 pm
Hello all, newbie here from missouri
I have gotten the generic benroy plans and have been going over them for about three weeks now, I have bought a HF 4 x 8 trailer and gotten it bolted together and ready to go,, but before i buy the wood and start building i need to know what fittings, trim, gaskets and other stuff to buy first, is there a "must have" BEFORE i start the build like door trim or molding??
Where can i find windows and slider screens for a 3/4 wall thickness??or can i make them? :thinking:
Does anyone have a wiring diagram for 110 volt only trailer?? i dont want to put 12 volt in at all. I saw one that used a GFCI for a breaker and it looked like it would work. Any ideas on that? :thinking:
I know from visiting this forum for hours on end that the answers are here cause there are alot of talented people in here. :applause: :applause:
thanks in advance
keith
Its better to not have awards and deserve them than it is to have awards and not deserve them.
-Not Me-
klattin3
Images: 16
Check out trippers index
Postby Guy » Wed Feb 13, 2008 10:54 pm
Dear Keith
Check out Steve Tripp's index for all of your questions. There is a link to all the answers
Here is the link http://www.tnttt.com/viewtopic.php?t=12276
Regards,
Guy
Guy
Images: 44
Postby oklahomajewel » Wed Feb 13, 2008 11:15 pm
<img src="http://lc.fdots.com/cc/lc/c0/c0f73c230176530aed33ce913627d473.gif" border="0" alt="MyHotComments.com">
Welcome and come camping with us soon.... there are a few folks camping at Lake Ozark in Mid MO in a couple of weeks, and you ought to see these in person and talk up a storm !!!
Julie
oklahomajewel
Images: 82
Postby klattin3 » Thu Feb 14, 2008 8:15 pm
That sounds great but i might be back on the road in march and i only get 10 - 12 days off every 6 weeks. :(
Well today i got the floor done and bolted on and both walls cut out and ready for final sanding. All in 6 hours and two trips to the lowes and home depot. :applause: :applause:
I have the cabinets, shelves really, laid out and the spar locations all laid out but the back galley walls dont look right so i will have to modify them.
-Not Me-
klattin3
Images: 16
Postby Miriam C. » Thu Feb 14, 2008 8:59 pm
Keith you need to dig out the camera. :thumbsup: Can you explain what doesn't look right about the back walls?
See if you have a picture then we can get that bubble oil level in a hurry.Image
We have Riches list up top and Sdtrippers index. Both are great resources. Also lil Bear (Grant_ has some I think. All up in the menu. :thumbsup:
You can also check out the salvage yards. They can be a boon for someone on the look.
Re: Newbie with a couple of ????'s
Postby madjack » Fri Feb 15, 2008 12:33 am
klattin3 wrote:Hello all, newbie here from missouri
thanks in advance
keith
...most trim and gaskets can be had from the local hardware store, RV repair place of trailer supply house(NAPA has much you can use)
...hardware and fittings can be had from www.austinhardware.com/ , FASTENAL or one of the TD parts suplliers...
...radiused corner "slider" windows can be had (cheapest) from RedNeckTrailerSupply...if you can't find an oputlet for them, try http://www.tjtrailers.com/store/ ...they can also be had from Grant at Lil Bear( http://teardrops.net/tdparts.html )
...you can't use a GFIC extension cord for a breaker...you can only use it for a GFIC, you can get a similar unit for the breakers...personally, I wouldn't wire it only for 120vac...it will hurt any furture resale value and limit your options...if I only went with one, it would be a 12vdc system...much more versatile...one of my favorite places for electrical oddities is www.waytekwire.com .....
madjack 8)
Postby exminnesotaboy » Fri Feb 15, 2008 7:16 am
Keith,
If you need some aluminum trim for your countertop(inside corner trim and edging), I have some extra still new in the package.
If you want to get an idea of what gaskets to buy, come take a look at our tear. Most can be found at your local hardware store. Hardware can be found at austinhardware.com and you can pick it up at their Lee's Summit location. I bought most of my items from Grant at Lil'Bear and was VERY happy with my purchases and reasonable shipping prices.
Drop me an email if you would like to stop by some time - weekends are best.
Tony & Kathy
exminnesotaboy
Postby MrBuzz » Fri Feb 15, 2008 11:25 am
Hi...Glad to hear you are getting going on your project!!
I used the same trailer and did 3/4" plywood walls too. Before you order windows check with some of your local aluminum recyclers. Many times they are scrapping toppers/campers/etc...that's where my windows came from. Very inexpensive that way.
Also, I found a lot of parts & supplies at the local home improvement store. Take an afternoon and just wander around all the departments of the store, it's amazing how many things you will find that can be used on your TD...saves tons of money over specialty items like fastners, latches and mouldings.
On my TD the drip rail moldings over the doors is a plastic molding that is used on suspended ceilings...I think it cost $3 and I got the two drip moldings out of it...bent it with my heat gun and gave it a shot of aluminum paint!
Good Luck!! Post lots of pix!
Generic Benroy - built 2007, 4X8, 1175 HF trailer, Structoglass roof and headliner, 12v and 110v electrics with Schumacher charger.
MrBuzz
Images: 77
Postby klattin3 » Fri Feb 15, 2008 6:31 pm
Thaks everybody, now i have more options :thumbsup:
Today i cut out the doors and made brackets to mount the walls and got the final sanding done along the outside edge. I would have gotten more done but i didnt start until 2:30 pm.
Tomorrow i am going to cut out for the hatch and paint the interior and hopefully stand the walls in place and hop to leave them up for good cause i took them down twice already :applause: :applause:
I will start an album tonight after supper so you can see how its going. :applause:
-Not Me-
klattin3
Images: 16
Postby klattin3 » Fri Feb 15, 2008 9:59 pm
:applause: :applause: Yay, thanks Miriam, i have an album. This is what i have done in two days not counting the trailer build. Still have a LONG way to go but its going smooth so far.
-Not Me-
klattin3
Images: 16
Postby Miriam C. » Fri Feb 15, 2008 10:21 pm
:applause: :thumbsup: ;) Wow that was fast! Great pictures and a really great start.
Now about that electrical. We have it all and you can probably start with the stickies at the top of the electrical forum. A couple of us have pictures in one thread here:
http://tnttt.com/viewtopic.php?t=20164
From simple to complex.
Mary K and Joanne have wonderful elect. plans so look them up. Joanne's are in the sticky and Mary K's are in her photobucket. Somewhere around page 14.
http://s101.photobucket.com/albums/m43/ ... ?start=260
Let us know if we can help. :thumbsup:
Postby b.bodemer » Sat Feb 16, 2008 4:11 pm
Looks like you are off to a great start!
:thumbsup: :thumbsup:
Barb
b.bodemer
Images: 328
Postby klattin3 » Sat Feb 16, 2008 4:14 pm
Thanks, i cant do any work today, supposed to get three inches of rain and turn to snow late and tomorrow. :cry:
I went back over the plans last night and almost skipped the galley step!! I probly could go back to it but the galley will help square the walls and save me that headache so i'll cut that and go in order.
I know madjack said it would be best to go with 12 volt only, but i dont do any rustic camping where there is no power so im going with 110 volt. I even have a plug in where i go deer hunting so the comforts of home arent very far :roll:
-Not Me-
klattin3
Images: 16
Postby Miriam C. » Sat Feb 16, 2008 5:51 pm
:lol: you can always use battery pop on lights in the event you go boondocking. (it's really one word) :roll: Missouri has lots of wonderful---free or nearly free camping.
Postby Boodro » Sat Feb 16, 2008 9:31 pm
klattin3 , just a thought , do you know how thick a mattress you will be using? The reason i ask is the bottom of your door looks a little high. When you sit up in the doorway , if you mattress is not high enough , your legs will be pinched . It can be very uncomfortable when getting in or out, & sitting. It seems the norm is the mattress is twice as high as the bottom of the doorway. You may have it covered but thought I would ask. It could save a HUGE headache later. Good luck on your build!! :thumbsup: :thumbsup:
We are all travelers in this world , from the sweet grass to the packin house , birth till death , we travel between the eternities . ( Robert Duvall as Prentiss Ritter)
Boodro
Images: 101
Users browsing this forum: IndigoIrish and 10 guests
