Floor width??
Floor width??
Postby shoeman » Tue Mar 04, 2008 1:50 pm
Starting my Generic Benroy based project next week. One question has sprung to mind: If the floor is 58.5" across, how well does a Queen mattress (60") fit in there??
The trailer is called 60", but that's the outer dimension.
Geoff
99% of the way done with a Generic Benroy. Only because these might never be done if you like to tinker. But it's on the road!
shoeman
Images: 22
Postby Toytaco2 » Tue Mar 04, 2008 1:58 pm
I believe the standard queen size bed is 60x80, so a standard queeen size mattress might be a little too big. A lot of people have suggested having a memory foam mattress custom cut to fit your cabin's demensions. That will be my own approach as my build will have small internal wheel wells to work around.
Toytaco2
Images: 368
Bed
Postby Maniac H3 » Tue Mar 04, 2008 2:04 pm
I use a Regular Queen Blowup in mine. I fits snug, but it does fit.
Maniac
Maniac H3
Images: 43
Postby MrBuzz » Tue Mar 04, 2008 3:25 pm
My TD is 4 foot wide, not a good size for a standard mattress. Instead of going with a custom-made foam mattress I used a queen-sized futon mattress that a friend "donated" to my project.
This type of mattress had a steel coil spring in the middle of it.
I took the mattress cover off and peeled back the padding. Then I cut the steel spring to the proper width and did the same with the padding.
I was going to re-size the original cover but decided it was easier to start from scratch. For the new cover I bought a sheet set from a department store and cut the fitted sheet to the top sheet to the proper dimension and sewed them together kind of like a huge pillowcase.
The finished mattress looks great and it sleeps well too(because of the steel inner spring).
Generic Benroy - built 2007, 4X8, 1175 HF trailer, Structoglass roof and headliner, 12v and 110v electrics with Schumacher charger.
MrBuzz
Images: 77
