Nigel wrote:Hi Classic Finn
They are about 20" fully extended. Could do with being a little longer hence the large bracket on the top.
My door is very light (maybe 10-15 kilo) but the shocks are very strong, one on its own managed to hold the door open (just). Not sure what car they are off, I have some friends with a garage who had them (they don't now)
WarPony wrote:I installed a couple of those gas struts on my hatch yesterday. The local RV dealer had a couple of 40 lb. struts in stock so I bought the brackets too and put 'em on. They look and work great!! Like Nigel did, I installed them so when the hatch is closing the struts have already gone over center and pull the hatch shut. I wish I could tell you I planned it that way buy I can't, it just happened that way.
Don't use any from a junkyard, they're probably worn out. The ones I bought were about $16 a piece so it wasn't a big hit on the checkbook.
Oh, BTW I weighed my hatch and it was about 27 lbs. How and where you mount the brackets will determine the poundage you need on the struts. There is a formula on McMaster-Carr's website but it was way off so I just bought the 40 pounders as a gauge to see if they were too light or too heavy. They are about 19 1/2" extended and 12" compressed.
Jeff
Nigel wrote:Yes they are stainless.
You will notice that I ran a bolt right thro the top fastener as it was putting too much side force on the bracket when I used the ball thing that they came with. Reinforcing the bottom ball thing by putting it on some 3mm plate helped.
Classic Finn wrote:Do you have pics of yours installed?
