mikeschn wrote:Andrew, did you have a plan for the corners somewhere?
mikeschn wrote:Those radiused corners are a tricky part, and I believe Andrew came up with a solution for that already. I'll see if I can find it.
Hmmmm, I can't find it right now... I could only find the Tinstream itself...
http://tnttt.com/viewto ... eam#170832
reiltear wrote:How about a $.99 beach ball of the size you like, wrapped in fiberglass, epoxied, faired, etc., then carefully cut into 8 "quarters"? This way you can also do the bottom "corners" or have spares for the top. I would paint them aluminum color, mount them on the frame and then wrap aluminum over, with a small overlap. Doing it like this would minimize the number of joints, hide the cut imperfections and possibly improve weather-proofing.
PS Inflate the ball first...
