eamarquardt wrote:Most of the stuff they sell is junk, IMHO. They do make things that see occasional use affordable (shrinkers, stretchers, die grinders, big cresent wrenches, power tools, etc.). If I am going to rely on something for reliable service, I'd think twice about using anything from Harbor Freight. Do a "potential problem analysis" and imagine what a "failure" might entail and act accordingly.
Hope this helps.
Cheers,
Gus
eamarquardt wrote:I thought I put in my message congratulations for thinking outside the box and contacting the tire company direct. This note must have been a "fig newton" of my imagination.
So......Good Job. Hold mfgrs accountable for defective products.
Cheers,
Gus
bobhenry wrote:If you put on your bifocals and get a magnifying glass it's on the side wall. "Max 60 psi cold."
Nitetimes wrote:bobhenry wrote:If you put on your bifocals and get a magnifying glass it's on the side wall. "Max 60 psi cold."
I think you've got your ammo right there... does it state a minimum tire pressure??? Max 60 psi cold would translate to no more than 60 psi when the tire is cold, if there is no minimum stated I would say it's their bad.
bobhenry wrote:...So those of you who chose to underinflate for a softer ride beware!
brian_bp wrote:bobhenry wrote:If you put on your bifocals and get a magnifying glass it's on the side wall. "Max 60 psi cold."
I agree that the "fine print" on tires can be really hard to read... the fact that it's only raised black rubber on black rubber doesn't help.
I sometimes actually take my glasses off and get my face really close to the sidewall to read tires; I'm sure I look ridiculous, but I can get the information. Even the most fundamental information - such as the size - can be hard to read.
With my (relatively recent) bifocals if find that it can be especially bad, because I am bending down to see the tire, and can't tilt my head back enough to see the tire through the bottom of the lenses, which is the near-distance part.
brian_bp wrote:Okay, so if the tire says nothing about pressure except the maximum, and I put in on my trailer and run it at zero pressure, should I be able to blame the tire manufacturer when it disintegrates? Doesn't the user of a product have some responsibility to learn how to use it properly? Does every bit of the information needed to operate a product need to be carved into the side of it?
