-Cliff
Cliffmeister2000 wrote:Progress is slowing down. I now have to think of the consequences of every decision.
-Cliff
The best example is paneling the inside after the roof spars are all in place
toypusher wrote:Cliff, That thing sure is looking good! Should be done in no time now!!
mikeschn wrote:Looking good Cliff!![]()
ARKPAT wrote:Cliff that is what I'm doing also. The LED lights save the battery with less current drawn from the battery ( as long as they are designed to work on 12 volt DC ). Some people do not like the LED lights inside all I can say is try one in the same kind of enviroment as you will be using them and see. If you do not like them exchange it or E-bay it and try the other versions out there till you find something you like and can afford.![]()
Pat
