Exterior Paint
Exterior Paint
Postby pete.wilson » Sun May 18, 2008 11:31 am
Hey
I just got finished painting a couple of boxes for the back of my suburban which were made from mostly 1/2" birch virnear plywood (cheap garbage wood) from Home Depot. I sanded the plywood and painted with Valspar Ultra premium exterior semi-gloss latex paint. I have used a 1/4" and 3/8" nap rollers and rolled the paint on, let the first dry and applied a second coat. The problem is the finnish comes out looking like it's textured and not smooth at all. While I don't mind it for this purpose, it would be lousy on the side of the house. Has anyone else run into this problem? Is there something wrong in my application? I wondering if it has to do with paint being so thick these days. Would oil base be better? Hand brush instead of roller? Thanks for the hlp and suggestions.
Pete Wilson
Why hasn't anyone found a dead bigfoot? When was the last time you found a dead deer, bear, coyote, fox, squirrel, etc. that died in the woods.........Hmmm.
pete.wilson
Postby Dean_A » Sun May 18, 2008 11:36 am
For latex paint on non-textured items, I always use foam rollers and get a pretty good finish. I always learned that the nap of the roller should correlate with the texture of the surface you are painting. Therefore no texture=no nap, i.e. a foam roller. I'm not a pro though. I'm sure some folks here might have better info.
Dean_A
Images: 55
Postby looped » Sun May 18, 2008 11:55 am
the foam roller will make it fairly smooth.
another idea would be to roll it on then chase it with a brush. one way to make it smoother would be to make a cup of very thinned paint and dampen the brush with it before smoothing.
"face it man. It's just not possible to fry an egg with a bicycle powered hairdryer!"
- Dave Lister
looped
Images: 31
Postby Airspeed » Sun May 18, 2008 4:31 pm
If you have a big enough compressor you could spray it, My first paint gun was from Harbor freight, it was a HVLP for about $20. You can spray just about anything with it and get a decent finish, certainly better than a roller or brush.
Aaron
Airspeed
Images: 16
