by angib » Tue May 27, 2008 8:29 am
There must be a router bit that will give the round-over radius you want, but I imagine it would have to be a big router and a big bit.
To do something like the deck edge radius on a yacht (say, 2"-4" radius), we would first trim by hand using a power planer to get something like the right shape and then sand it by hand using a sanding block, checking regularly with a radius template.
One of the two tricks with sanding a rounded edge is in using a long, narrow sanding block that has the sandpaper stuck to it. Doing this job with a power sander won't work - it's just too hard not to take off too much material and create flat spots. Clearly, doing it by hand isn't a 10-minute job, but if you want it right.....
The second and most important trick is to move the sanding block correctly - the block is aligned along the edge and moved diagonally - so not only does it move along the joint, it also rotates around the radius, and that rotation is 100% essential. You cannot get a smooth radius if you try to sand at a constant angle. If you have bad wrists, you need to find someone else to do this job!
If the joint gets to a tight curve, switch to a shorter sanding block but keep the same diagonal, rotating motion.
This job sounds like it requires an impossible level of skill, or hand-eye coordination, to make an exact radius, but it's surprisingly easy to do once you take the plunge. I can do it, so it's neither skilled or hard.....
Andrew
