plywood thickness and type
Postby limptera13 » Wed May 28, 2008 8:44 pm
my main question is i can run into a lot of free parts in my first attempt to build a teardrop, i already got a free trailer, needs a lil work but it was free, and i came into 4 pieces and just i guess regular plywood 1/2 thick 4x10ft odd that its so long, and about 4 more 4x8 pieces of plywood. all free, and my glass for windows aare free, and the labor that my dads been a carpenter for his whole life comes free as well, now i read that for the floor and sidewalls to use 3/4 inch plywood, would 1/2 be ok, and is the type only for look purposes? so to sum it up since i confused my self
1- can i use 1/2" plywood for the floor and sidewalls
2- is the type of plywood, birch etc, just for quality of finish purposes?
3- and could a 4x10ft weekender teardrop work and or make sense to build(have a 15 ft trailer)
limptera13
Postby BrwBier » Wed May 28, 2008 9:04 pm
1-yes
2-yes
3-yes
Your not confused, you got it all right. And the free labor cant be beat.
Brwbier
BrwBier
Images: 100
Postby madjack » Wed May 28, 2008 9:12 pm
1...yes you can...we use 1/2 for our floors and 3/4 for walls...you can use 1/2 for walls but may need to add some framing at attachment points for screws to bite into.....
2...yes you can...we use cabinet grade birch ply...this ply may be intended for interior use but unless it states that it is for interior use only, it probably has a water resistant glue...if you do as we do and seal it, especially the edges, with epoxy(as many as 3 coats) it should be impervious to most of the elements....
3...why the heck not..it's yours and you will be building it...4x8, 4x9, 4x10, 5xany, 6xany, etc...it's yours, doityourway!!!!!!!!!
madjack 8)
p.s. FREE is good!!!!!!!!!!!!!!!!! :thumbsup: .........MJ
Postby satch » Wed May 28, 2008 9:50 pm
Mine is 1/4" top, 1/8" bottom, sandwitched 3/4" insulation. works great, exept the galley is 3/4" ply just because of the refer and cabnets there 8)
If it itches. scratch it
Rick
satch
Images: 63
Postby bobhenry » Thu May 29, 2008 7:07 am
I used old weathered 1/2" osb for my sides ( yeah it was free ). When I was done framing I glued 1/4 luan over the outside and routered off the excess. Still needs trim but I'm on teardrop time !
Postby limptera13 » Thu May 29, 2008 10:56 pm
lol ,my plywood looks like it belongs in a mansion compared to that haha but all that matters is the finished look and urs looks damn good hopemine can look that good
limptera13
