Mstro wrote:Mike thanks for the lead - It pushed the thought process and this is the first thought to show - the fold would be opposite the Kampmaster, Laying down when the top folds, the hard part I see would be support in the door opening during travel, fearing wall flex. Challenging at best![]()
mikeschn wrote:
mikeschn wrote:Doug,
Yes, I'd love to be able to have it fit in the garage. In terms of height, I'd probably plan on a dropped floor in the aisle, at least as an option. Then without the dropped floor it would be a slouchie.
Greg,
I'm interested in your cell phone pictures.
Puptent,
That sounds like the Generic ET! or the Tailgater... And that just too big to be a lightweight. By adding the bathroom, I have to give up the galley.
I thought about the tab profile too, but it's too hard to bend the plywood around the tail.
joecnc2006 wrote:mikeschn wrote:
mike what program do you use for the great looking designs, and also the nice pictures in the Benroy plans?
Joe
Mstro wrote:Thanks Mike
You helped put me on different road and i like it![]()
Now to fine tune and get going on making the real thing![]()
Hope to make a firm start soon
angib wrote:Marc,
That way you might be able to open the lower door even when the roof is down, which would be very convenient - the alternative is that you have to be able to raise all of the roof and side panels without ever going inside, which is a big ask.
Andrew
Mike wrote
Why not hinge the front panel right across the middle, and you can leave it attached permanently.
Of course I say that, but I haven't had a chance to look at that in CAD yet... it might not even be doable.
Andrew wrote
Marc,
Don't overlook the simple idea of just making the top of the door detachable - maybe with a couple of metal pegs sticking out from its bottom that fit into holes in the top of the lower door. If you've ever seen the sidescreens on an old Brit sports car, you'd get the idea!
Andrew
Mike wrote
I thought about that last night too. With the hinged door top, you would have to raise the top to get in on that side. A couple options are:
1) to put a small door on the other side.
2) to put a door within a door on the curb side
