...thx, I'll check it out..calumet wrote:Hey, daddio…was reading your thread and noticed that you were looking for an affordable fantastic fan roof vent. I got the idea from others on this site of using a 12v 10” fan ($13 from Wal-Mart) suspended below a plain roof vent and it works great. $45 total in my case and the fan has the versatility to be used in a myriad of other functions.
oklahomajewel wrote:
And then what would be used to seal/trim the seams on the exterior?
Thanks !
daddiozz wrote:OK/jewel you asked ..so here it is
northern tools/HF 4x8 trl kit w/13" rims/tires...................$336
building supplies....all amts rounded off to nearest $1
plywood,one sheet 5/8.........................................24
2x4x8, 5ea..........................................................13
2 1/4 woodscrews , 1 box......................................6
deck adhesive, 1 tube...........................................4
pvc pipe 3/4" x5', 50 @1.57...................................75
pvc fittings.........."T" ,80 @ .25.............................20
" " 3 way elbows..4 x 1.49................6
" " 45* elbows.....8 x .79..................7
" " 4 way cross......12 x 2.50..............30
pvc solvent cement ....1 pint..................................10
pvc sheets ...4'x 8' x 3mm.......2 x29......................58
" " " " " 2 x 34.....................68
1" conduit straps (steel)......47 cents x 30................15
1/8 aluminium rivets........1 pkg (100 ea)..................5
aluminium piano hinge ....2 x 8................................16
door latches.........2 x 6...........................................12
silicone caulk........3 tubes x4.................................12
misc hardware......................................................25
.........................................................ttl ........................$406
tools purchased
rivet gun...........................................................18
miter box/saw combo.........................................16
miter/chop saw (yardsale item,dewalt 14")...........50
jigsaw....................".........................................10
drill bits/jigsaw blades........................................10
ttl ..............................$ 104
misc expenses
gas running to/fro ...........................................32
beer...............................................................32
ER visit............................................................0
grand total so far .................................................$852![]()
The feeling of taking out the Tear on that first trip: Priceless
oklahomajewel wrote:Congrats on your first campable trip.... hopefully the cracking problem won't happen when you get insulation, interior skins on and create a "sandwich" wall...
You still have me dreaming and scheming of possibly building a little bit larger trailer for me and my stuff !
Miriam C. wrote::applause:You made it! Are your sides riveted to each framing piece? Is there a such thing as a pvc rivet? Sure hope it gets worked out. It is sounding like this is going to be comparable to a woodie when done.
Good luck!
...well like I said ,these fit perfectly and they come already upholstered/covered ...camo on one ,buzz lightyear on the other and very comfortable ...lol....when not in use as beds ,fold em up into "chairs" against the front wall and ..viola'... lots of cargo room.Miriam C. wrote::lol: Glad you found something for a bed. You can get foam cut to order at Knox foam. Google it.Also Walmart has wonderful foam mattresses just cut to size.
