len19070 wrote:I used/built Sliding doors in my Galley. I liked them so much I used them on the inside too. Mine is a copy of a 1947 trailer and in the photos I had it had doors that swung up. Making it necessary to clear the counter top of all tall items so you could open the door. Inside as well they cured the problem of "ducking your head" every time you want to open a cabinet. Also unless you hinged an interior door in the center of the coach. When the door is open you block your entrance door opening, or at least the upper part. With the sliding doors you don't have to get into the coach to get, or put something in the cabinet.
http://pg.photos.yahoo.com/ph/len19070/ ... 3f&.src=ph
Happy Trails
Len
angib wrote:a cotter pin ('split pin' in the US?) was pushed through a hole in the middle of the upper track/rail,
Chris C wrote:"worked a treat"?
angib wrote:Sticking with the same subject, those Merkans seem to have a dance called 'The Shag'.
We do not have that dance in Britain.![]()
Well, we certainly do have it, but it's not really what you'd call a dance.![]()
Andrew
Steve Frederick wrote:Geron, Just took a peek at your build journal! You've got a really petty Tear there!!![]()
Your work looks to be first rate!! Nice job!
