When to put in tile floor
Postby zlamb0002 » Mon Nov 10, 2008 1:53 am
I was wondering when the best time to put the flooring in my teardrop.
before I add any of the walls
after the outside walls are up
after all walls are up
zlamb0002
Postby GPW » Mon Nov 10, 2008 7:21 am
After you've completely sealed the floor... :thumbsup:
Postby starleen2 » Mon Nov 10, 2008 8:23 am
Just remember that you'll be crawling around in there during the constuction process - If the flooring is down at when the outside walls are up, then it needs to be protected during construction. I put my flooring down after the walls went up and placed some carpeting turned face down to protect the floor during final installation. It really helped - especially when I dropped drills, saws, and screwdrivers on the floor!
starleen2
5th Teardrop Club
Postby Loader » Mon Nov 10, 2008 9:47 am
I think either time will work, I choose to install the tile prior to the walls going up.
Like already mentioned, you just need to be careful, using scrap carpet, cardboard boxes, or some sort of tarp to cover it.
I just thought it would be easier to install before the walls, as compared to triming the tile (if needed) after the walls were up.
Earl & Kerry
"Loader"
Loader
Images: 245
Postby planovet » Mon Nov 10, 2008 10:06 am
Loader wrote:I just thought it would be easier to install before the walls, as compared to triming the tile (if needed) after the walls were up.
Same here. It seemed it would be easier than crawling in and out of the tear while installing them.
ImageMark (& Cindi)
planovet
The Cat Man
Users browsing this forum: Jimbodub and 5 guests
