Miriam C. wrote::( You should never run 12vdc and 120vAC together. If you have a short for any reason the you could have 120vAC flowing through the 12vDC. Bad Bad Bad! Not only are you risking a fire but electrocution.
Not only would I run them in different conduit, I would mark the conduit and put it on different sides. Electrical mistakes are rarely forgiving.
Greg M wrote:...Then bad things happen, and all the smoke comes out of your stuff.
starleen2 wrote:There will be some that have done it with no problems, however, that doesn't mean it's right - i prefer to keep things separate to eliminate the possibility of problems -electricity is so silent until it strikes - you wouldn't run drinking water and sewer water in the same pipe - would you?
Greg M wrote:It's also against the electrical code. The insulation on the 12 volt wire isn't rated for the voltages that household wire can carry. If the 120 volt conductor becomes exposed it could, theoretically, arc through into the 12 volt wiring. Then bad things happen, and all the smoke comes out of your stuff.
-Greg
