Clamps
Clamps
Postby Dewi » Fri Mar 13, 2009 6:45 am
I know this isn't a good start, but I don't think I own any clamps... I have our Grandad's workbench with a vice, but no clamps.
Was wondering what clamps you guys use and more importantly why, and what for?
I don't really want to ask at the DIY shop because I just know that half the stuff they recommend will sit unused in a tool box for the next 2 years until we build a chicken coop or something :oops:
Cheers, Dewi
Dewi
Postby satch » Fri Mar 13, 2009 7:59 am
I used mainly bar clamps amd pipe clamps.Pretty much any type would work depending on what your clamping. Just keep in mind, if you think you have enough clamps, go get more. You will need them!
I bought alot from Harbor Frieght when on sale. The motto is "You can never have too many clamps"
If it itches. scratch it
Rick
satch
Images: 63
Postby Mark McD » Fri Mar 13, 2009 8:02 am
Bar clamps are essential. Spring clamps are also handy, especially for lofting curves.
I like turtles
Mark
I don't feel tardy
Mark McD
Images: 63
Postby Dewi » Fri Mar 13, 2009 8:08 am
I think our equivelant of a bar clamp is called a sash clamp over here... what sort of widths would you recommend? Found a 48 inch for £8.80 (about $12)... does that sound cheap, expensive or about right?
Cheers, Dewi
Dewi
Postby aggie79 » Fri Mar 13, 2009 8:12 am
Spring clamps, bar clamps, c-clamps, & pipe clamps. This is what I had before I started (pipe clamps & c-clamps not shown.)
It really depends on how you build your floor and walls. If you keep it simple and don't insulate your walls, you can get by with a few bar clamps or pipe clamps.
Postby planovet » Fri Mar 13, 2009 8:24 am
I think a mantra on this forum is that you can never have too many clamps. Bar clamps are good but so are cheap spring clamps. I have accumulated many clamps during my build.
ImageMark (& Cindi)
planovet
The Cat Man
Postby oldschoolimport » Fri Mar 13, 2009 8:33 am
planovet wrote:
thats alotta clamps!!!! Image
oldschoolimport
Postby Dewi » Fri Mar 13, 2009 8:35 am
Blimey, that's a lot of clamps!
Could you help me identify what the bar and pipe clamps are here...
http://www.tooled-up.com/SubCategory.as ... 4&SCID=116
The spring clamps come under the same name and I think we call bar clamps as sash clamps... but pipe clamps? :?
Cheers, Dewi
Dewi
Postby starleen2 » Fri Mar 13, 2009 8:40 am
This is a pipe clamp - it gets its name due to the "pipe" used in its construction - the advantage of this type of clamps is that the pipe can be any length that the owner chooses
starleen2
5th Teardrop Club
Postby Classic Finn » Fri Mar 13, 2009 9:18 am
aggie79 wrote:Spring clamps, bar clamps, c-clamps, & pipe clamps. This is what I had before I started (pipe clamps & c-clamps not shown.)
Now that is one clean lookin shop :lol: :lol: Yes for certain clamps and more clamps. The more the better. You just cant have enough.
Ive got dozens of small size clamps and 4 very long ones that are 2m meters across each. As well as 1 meter in length. I think I still dont have enough :lol:
Classic Finn ;)
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Classic Finn » Fri Mar 13, 2009 9:22 am
planovet wrote:I think a mantra on this forum is that you can never have too many clamps. Bar clamps are good but so are cheap spring clamps. I have accumulated many clamps during my build.
Have to agree with you on that one. I also have the bar clamps as well as real cheapy spring clamps here. ;)
Classic Finn
Images: 146
Postby planovet » Fri Mar 13, 2009 10:01 am
starleen2 wrote:Image
That's your typical pipe clamp (great picture). You buy the ends and then you buy the pipe separate. You can buy different lengths of pipe and just switch out the clamp ends as needed.
I used bar clamps also. They are handy but are limited in length (usually 36-48").
ImageMark (& Cindi)
planovet
The Cat Man
Postby planovet » Fri Mar 13, 2009 10:29 am
Dewi wrote:Blimey, that's a lot of clamps!
Not as many as some I have seen on here :lol:
Here is a good clamp thread Link
ImageMark (& Cindi)
planovet
The Cat Man
Postby b.bodemer » Fri Mar 13, 2009 11:39 am
Reminded me that besides clamps my kayak straps and extra lumber helped too.
This was my test on how the birch would bend over my 24" front radius.
Then the final setup when I glued it into place with clamps and straps.
Barb
b.bodemer
Images: 328
Postby Dean_A » Fri Mar 13, 2009 12:19 pm
Ditto. Spring clamps, bar clamps and pipe clamps. If you think you already have enough, you're wrong. :lol:
Dean_A
Images: 55
Users browsing this forum: jfc and 6 guests
