chev59_99 wrote:Questions
1. what is a good size tire for this 8 or 12 .
Just about any size of trailer tire will have enough load capacity, so I think this comes down to ride/handling and appearance. With a Harley tug, I have to think that bigger will look better; to me, B52's trailer looks good and would not look as good with 8" wheels.
chev59_99 wrote:2. What is a good tongue length from front of trailer to hitch.
I don't think that dimension really matters. What matters are distance from the ball to the trailer axle (longer is better for stabilty), and weight distribution (centred a reasonable amount forward of the axle. The part of that length which is tongue (ahead of the body) just works out to whatever it works out to, from nearly zero (unlikely because less than 3' ball to axle will be too short to be stable) to a few feet if you want.
chev59_99 wrote:3. what torsion axle load rate my choices are 425 550 or 900 lbs. would be good and where is a cheap place to get a good pair.
I think that the lowest capacity which is adequate for the highest anticipated load is desireable, to have the softest possible springing, for the least jarring ride. Will this trailer be more than 425 lb when loaded?
chev59_99 wrote:4. will this be to wide frame 36 plus wheels sticking out. my top for this is about 34 wide but may want to put better one on later and don't know size.
I think that this is an air drag and manoeuverability issue; I don't think there's a right answer. Any width which fits the 34" wide box will likely have enough track width for a trailer of this height to be stable, assuming that the trailer is to be built as low as possible to complement the bike.
chev59_99 wrote:5. Does anyone have a good design for a 360 degree swivel hitch.
The off-road people, in addition to of course other bike people, are the experts in this. I tend to believe that the ball has enough rotation angle for a non-sport bike, but I would put a coupler on a ball to check the travel angle, and compare that to the lean limit for the bike, before making any decisions. European overrun-braking couplers seem to be routinely constructed so that they can rotate, which could be another solution, but they are not readily available here and would not be available in a 1-7/8" ball size.
chev59_99 wrote:7. I have never used torsion axles and don't think I need adjustable ones for this right or wrong ?
The adjustment is to allow ride height adjustment, which is great if you do not know in advance how high everything is going to come out, or if you want an angle which is not available in the fixed-angle designs. Personally, I think that I would prefer adjustment but would not take a heavier and stiffer axle (in a higher capacity range) than necessary in order to get the adjustment. Fortunately, the lightest readily-available rubber axle assemblies that I know of are the Flexiride units, which are available with adjustable arms in the lightest range; it appears that "-S" on the end of the model name (e.g. FR-425-S, rather than FR-425) indicates
Splined, meaning adjustable.
