They seem to work pretty good. Alittle tricky to put in when I am inside, but aftr a few times they went pretty good. Erv
ERV wrote:Yes I was going to use to small hinges but the frames are to thin, Couldn't get the screws to hold in the metal. I used some tape I had to seal the windows here at home. It is clear and sticks really good. Should last a good long time. I also let the screen run from one panel to the other so the screen will give a little more strength too. Erv
