How about vinyl or naugahyde to cover teardrop?
Postby Airmad » Tue Jul 21, 2009 5:15 pm
Have any of you guys tried to cover your trailer with vinyl or naugahyde? I used aluminum on my Benroy, but it was expensive, and a pain to work with. Covering with vinyl or naugahyde would be similar to the old vinyl tops on cars and should be easy to do. Should be lighter too.
If you've done it, what did you use, and how do you like it?
What do you think?
Thanks.
Airmad
Airmad
Postby planovet » Tue Jul 21, 2009 5:21 pm
Many have used vinyl on their roofs. Creamcracker for one...Link
ImageMark (& Cindi)
planovet
The Cat Man
Postby Barry and Darby H. » Tue Jul 21, 2009 5:22 pm
I used marine grade vinyl on my roof and have had good luck so far. I went with padded vinyl and you can't even hear the rain drops.
Barry and Darby H.
Images: 29
That's great guys. Thanks.
Postby Airmad » Tue Jul 21, 2009 5:29 pm
Thanks for getting back to me so soon. I'll call the local boat guys tomorrow and see what they have. I like the wooden strip down the centre. great way to cover the seam, and nice design feature.
Airmad.
Airmad
Postby Creamcracker » Tue Jul 21, 2009 5:50 pm
Yepper...got my marine vinyl at Joann Fabrics...Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby boomboomtulum » Tue Jul 21, 2009 6:56 pm
I went to a local upholstery shop and they ordered me enough material to cover mine. It is a vinyl top material. I needed 5 ft. wide and seemed to be hard to find in the material I was lookng for. I glued and stapled down a 3/8 foam directly to the CPES top. Then worked my way around the edges, pulling slightly and stapling down the material, no glue under vinyl, them trimmed it out with alluminum. No problem at 70 mph across Nevada, and Utah. Last week.
Hit the link below you can see part of the top.
Dave
http://www.mikenchell.com/forums/album_ ... c_id=37109
Have'nt been everywhere yet, but it's on my list.
boomboomtulum
Images: 50
Postby caseydog » Tue Jul 21, 2009 7:24 pm
I know of one. It is a good material, but just make sure you really glue it down well, or as you go down the highway, it will lift and make a big bubble.
I'm sure you have seen it on an old car with a vinyl top, and one of our forum members has experienced it.
Put your vinyl down with contact cement, by the book. No shortcuts. Do it right,a nd you have a great top that is durable, and helps kill the sound of rain when you sleep on a rainstorm.
CD
My build journal is HERE
caseydog
Images: 515
Postby Creamcracker » Tue Jul 21, 2009 7:47 pm
caseydog wrote:I know of one. It is a good material, but just make sure you really glue it down well, or as you go down the highway, it will lift and make a big bubble.
CD
Like a previous poster I did not glue mine down....and I have had no problems. Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby oklahomajewel » Tue Jul 21, 2009 8:58 pm
Joyce Porter on here was at Crawford campout last year (look in the northcentral threads from last october) and has a "convertible"
top made by an Amish buggy maker, using the materal and snaps down the edge... she had him do the snaps too. Sharp!
julie
oklahomajewel
Images: 82
Postby kennyrayandersen » Wed Jul 22, 2009 4:12 am
I just couldn't bear having to kill all of the naugas just to make a vain roof :(
:lol: :lol: :lol:
Just use Corinthian leather instead! :R
kennyrayandersen
Images: 38
Postby dguff » Wed Jul 22, 2009 9:49 am
Check out the Brun-Tuff vinyl on www.yourautotrim.com I have it on the top of my trailer and it has been no problem for two tears now.
Jerome
Jerome
2008 Guffman
dguff
Images: 69
Postby DBizer » Wed Jul 22, 2009 12:01 pm
Yep, mine is the "Brun-tuff" vinyl that Jerome mentioned. Yes it's glued down and has 1/8" foam under it.
Bubbles a little when its 110 degrees and in the sun (they go away when it cools off), but no bubbling going down the highway!
David
"It's not that there are not enough hours in the day, it's that there are not enough days in the weekend !!! "
DBizer
Images: 57
Postby Creamcracker » Wed Jul 22, 2009 1:21 pm
DBizer wrote:Yep, mine is the "Brun-tuff" vinyl that Jerome mentioned. Yes it's glued down and has 1/8" foam under it.
David
That was why, after much research, and having worked with vinyl before, I decided not to glue mine down ( does have a foam layer beneath which is glued down)....it does not bubble whatsoever even in the hottest of days with the sun beating directly down on it. It also doesn't lift from the roof when I'm going down the road...I have heard that happens with some teardrops....maybe it's just to do with the particular curve of the teardrop roof or just how far up the leading edge of the hatch comes...I don't know but it doesn't.
Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby boomboomtulum » Fri Jul 24, 2009 1:31 pm
David
Philip
Which is exactly why I did not glue down the vinyl material, a recomendation from the supplier, he said in high heat, if glued you will see bubbles, only attach around the edges so the material can move as in needs to. Worked for me.
Dave
boomboomtulum
Images: 50
Postby Mauleskinner » Fri Jul 24, 2009 6:45 pm
caseydog wrote:...and helps kill the sound of rain when you sleep on a rainstorm.
CD
exactly why I'll never put vinyl on the roof...I can stay at home if I don't want to hear the rain! :D
Mauleskinner
