SlyTerry wrote:2 tires at 500 lbs will do the trick but as you probably noticed that on very few trailers does the tire capacity is the limiting factor...The weakest link in the chain determines the capacity of the trailer. usually its the suspension...
48Rob wrote:Sean,
Together, the two equal 1000#...but I'd hesitate to run that close to the limit.
If your trailer weighs 1000 pounds, and the weight is even side to side, you have little to no margin for error.
If your weight is not evenly divided, then you are "over" on one side.
If you hit a good bump the 500 pounds will equal much more slamming down.
A 1350-1500 pound rating would give you a realistic margin.
Rob
Lgboro wrote:All well and good if the tires weren't manufactured years ago and dry rotted. Many tire sold in the US today were made years ago and have been in storage.
Rob, though I would agree you don’t want to push the limit so close, I’m 99 44/100s percent sure that the tire mfg has taken the dynamic loads into consideration
48Rob wrote:Rob, though I would agree you don’t want to push the limit so close, I’m 99 44/100s percent sure that the tire mfg has taken the dynamic loads into consideration
Kenny,
You may well be right...
No doubt manufacturers and their lawyers leave a margin for error, but the same lawyers would rake me over the coals if I had an accident that hurt someone because "I" didn't allow a large enough margin on my end...
Of course they can't publish the "real" numbers, or the game would be ruined.
Who'd have thought buying a set of tires for a trailer could be so complicated![]()
Rob
48Rob wrote:Sean,
Rob
