BrianB wrote:How about this. If you want to cover the frame like I do, weld on a lip the same width as the thickness of your plywood onto the bottom of the frame. Do it so that it supports the edge of the plywood so that you can screw the plywood into both the frame AND floor without the shear loading issues.![]()
regis101 wrote:So in the pic, the frame is the tube trailer frame? The lip is some flat stock that protrudes past the frame perimeter for the outside wall to set upon?
Uber strong if that's the case, IMO.
alanv73 wrote:Are you saying you didn't even use screws at all to hold the sides on?
kennyrayandersen wrote:It would certainly keep the walls from separating from the floor (which has been a problem from time to time it seems).
