Door locks and galley locks
Postby Danny » Sat Aug 15, 2009 9:52 pm
O.K., what do you suggest for 1" thick doors? I have a plywood stop inside the jamb like Steve F. and others have used. I have seen the kind where you drill a 7/8 hole and shove the cylinder through they have a 5/16" throw. Any other ideas?
Danny
Images: 108
lock
Postby Danny » Sat Aug 15, 2009 10:00 pm
Image my concern is the mounting bracket will have to be so close to the door edge that it will come between the door and the inside plywood stop lip.. I have not bought these yet but, see nothing else out there that will work.
Danny
Images: 108
Re: lock
Postby Danny » Sun Aug 16, 2009 10:08 am
Danny wrote:Image my concern is the mounting bracket will have to be so close to the door edge that it will come between the door and the inside plywood stop lip.. I have not bought these yet but, see nothing else out there that will work.
O.K. the longest one I can find has a cylinder length of 1 1/8 so, if I put a 1/4" block where the lock will mount inside the door the throw will work perfectly to catch the back of the plywood stop. The front of the lock(outside will be recessed 1/8". Not ideal but it will work. The only other way is to recess the the mounting bracket into the door and notch the jamb just behind the door lip stop. chisel work.
Danny
Images: 108
Postby Danny » Thu Aug 20, 2009 6:27 pm
update. I ended up going with a cam lock I found at the box store. It went in well and looks great & does it's job. This was used on the door. on the inside I am going to use old fashioned bolt locks.
Danny
Images: 108
Postby bg » Thu Aug 20, 2009 10:56 pm
why not use a set like this?
Bobby(, Kim & Wayne)
bg
Postby Danny » Fri Aug 21, 2009 3:21 pm
bg wrote:why not use a set like this?
nice looking set but, I don't like ebay,Idont like paypal,I don't like banks and credit cards and, I dont like 13 bucks in shipping fees on top of the price.
Danny
Images: 108
