under carriage
under carriage
Postby TD_Dodger » Sat Aug 22, 2009 8:56 pm
Hey guys i just sprayed some undercarriage on the bottom part of the plywood, it took 2 cans at 3.99 at the local ace shop.
do you think its enough against the road and weather. the teardrop will be in the garage away when not in use.
http://tnttt.com/album_ ... c_id=54392
TD_Dodger
Images: 61
Re: under carriage
Postby Steve_Cox » Sat Aug 22, 2009 9:48 pm
TD_Dodger wrote:Hey guys i just sprayed some undercarriage on the bottom part of the plywood, it took 2 cans at 3.99 at the local ace shop.
The most vulnerable place on the plywood is the endgrain, that is the place that usually wicks up the water and causes delamination. Is your undercoating enough? I dunno, did you make it waterproof?
I went to an extreme to prevent water from entering the plywood floor on my teardrop, it was encapsulated in epoxy resin, the end grain got 3 coats the flat exterior 2 coats. Then it was coated with the black goo from hell, better know as plastic roof coating mostly to absorb the impact of road debris, rocks, etc. It's another one of those "personal preference" things.
Steve_Cox
Images: 196
Postby TD_Dodger » Sat Aug 22, 2009 10:41 pm
waterproof? ohhh darn. this spray i got i guess its the same as the kind they spray under automobiles. its says its rust, water, and so on resistant, it also reduces noise so it says. i have some paper they place on the roof before placing chingels, im gonna put some on there. it had some of that when i first got it. man do i hope this helps, im gonna get a couple more cans on monday and spray the sides where you said its vulnerable. thanks for the help buddy. :D
TD_Dodger
Images: 61
Postby Juneaudave » Sat Aug 22, 2009 10:47 pm
Looks like you got that trailer better than new!!! Nice job! :thumbsup:
Juneaudave
Images: 380
Postby 2bits » Sat Aug 22, 2009 11:40 pm
I originally used some of the spray automotive undercoating and I didn't feel comfortable with it at all, way too thin for my taste. I covered it with the roof tar and I felt better. You can see the old and the new right as I was finishing putting on the tar.
Thomas
2bits
2bit Member
Postby Miriam C. » Sun Aug 23, 2009 8:04 am
TD_Dodger wrote:waterproof? ohhh darn. this spray i got i guess its the same as the kind they spray under automobiles. its says its rust, water, and so on resistant, it also reduces noise so it says. i have some paper they place on the roof before placing chingels, im gonna put some on there. it had some of that when i first got it. man do i hope this helps, im gonna get a couple more cans on monday and spray the sides where you said its vulnerable. thanks for the help buddy. :D
Sometimes when you go adding stuff to keep out water you make a water trap. Best to leave the treated ply to drain. mho.
Postby chorizon » Sun Aug 23, 2009 9:00 am
Miriam C wrote:Sometimes when you go adding stuff to keep out water you make a water trap. Best to leave the treated ply to drain. mho.
Miriam, what if the ply is untreated, should I coat the bottom edge with something?
chorizon
Images: 94
Postby TD_Dodger » Sun Aug 23, 2009 2:28 pm
Juneaudave wrote:Looks like you got that trailer better than new!!! Nice job! :thumbsup:
Thank you for the compliment it feels good to hear that
TD_Dodger
Images: 61
Postby Juneaudave » Sun Aug 23, 2009 2:38 pm
I meant it!!! I can't tell for sure all you did, but the transformation is something!!! :applause:
Before
After
Before
After
Juneaudave
Images: 380
Postby kennyrayandersen » Sun Aug 23, 2009 7:47 pm
Spankingly nice! :thumbsup: :applause:
kennyrayandersen
Images: 38
