I love the look of the Lil Diner. I am in the scheming and dreaming stage now. Hope to start by December this year. I am planning on getting Steve's manual, but had a couple of questions.
1) The Lil Diner was built a few years ago - I have searched and have seen a lot of interest, but has anyone else actually built this design? What changes/improvements have you done? i.e. I read a comment by Mike that he would make it 6ft wide next time. Also if you have built it does it still fit your needs - do you use the table that much?
2) I also saw a comment that you only need a 5x8 trailer for the original design. I was thinking about having a 6x10 trailer built for it partly because I want a hitch on the back - is this overkill?
3) Is it advisable to match the size of tires on the trailer to the tow vehicle or adjust the trailer towing height with a drop down hitch and stick with 12 inch tires? (1/2 ton GMC pickup is tow vehicle).
4) I will use this to fish on or near the beach a lot - is Aluminum advisable for this application-sand and salt. I was thinking of a Shiny Diner!
5) What kind of problems will I encounter with a 6ft interior width (62.5 outside width) i.e. will I be able to find aluminum in that width and necessary length?
Thank you for the help!
