RichAFix wrote:My floor is a sandwich type construction:
.25" birch plywood/.75" poplar framing with pink .75" insulation/.25" birch plywood.
I don't know what kind of frame you have underneath it, but this is very strong, no flex at all and the poplar gives me a good screw hold for when the sides are attached. I tend to overdo things so my sides are also glued into a dado the length of the trailer. That dado also keeps the floor straight.
sjacobso76 wrote:Thanks guys! So do you put the cross members at 16" on center?! Also, do you think the footwell storage type thing would weaken this at all? I would think that could have an effect as the sandwich seems like it acts as a torsion box to keep everything rigid.
sjacobso76 wrote:Is 3/4" enough insulation? It doesn't seem like much to me, but I really don't know anything about trailers. Does anyone use High-R value insulation (the foil faced stuff) to get more R value in there?
sjacobso76 wrote:So if you don't put insulation into the floor, would you still build a torsion box for the floor? It makes sense that it would be the lightest way to create a very strong floor.
alffink wrote:Insulation - No Insulation - always a hot button issue, but I looked at it this way, the rigid foam weighs next to nothing and nearly as inexspensive, to insure that the floor, walls and cieling does not form condensation where using the mattress as the insulation, may insulate you but does nothing to protect the interior of your tear. Just be sure to concentrate on sealing the floor and walls, etcetera. You'd best be sure it's sealed, even if going without the foam.
But, to each his own, weigh the pros and cons and decide for yourself, based on what you want, for the areas that you will be camping in.
LMarsh wrote: Needless to say I'm a warm sleeper though, especially after those Rochester NY garbage plates! Lots of fuel in them.![]()
Lucas
