Propane Tank Placement?
Postby wlivesey » Sun Sep 06, 2009 1:51 pm
I'm almost afraid to ask but here it goes... Is it okay to put my propane tank under the galley rather than on the tongue? I only need propane for a stove and nothing else. Keep in mind, I'm building a standy, so the galley is inside.
wlivesey
Images: 283
Postby teardrop_focus » Sun Sep 06, 2009 2:17 pm
Only if the area immediately surrounding the tank is completely sealed from the trailer's interior... and extremely well-vented to ambient air. The possible configurations of such a placement are numerous.
:pipe:
:SG
teardrop_focus
Images: 127
Postby wlivesey » Sun Sep 06, 2009 4:49 pm
That's what I thought. Thanks for the confirmation.
Bill
wlivesey
Images: 283
Postby Shadow Catcher » Sun Sep 06, 2009 6:10 pm
You should also have a gas and CO detector.
There was a fire in a facility that loaded propane cylinders as part of the exchange your empty one for mostly full one in the Toledo area. The video was rather entertaining, some taking off like rockets and one on the ground spinning like pinwheel. Gas in a confided space, bad thing. One other thing to consider is that the valve is designed to come off in a fire or impact so A. I want it out side pointed up and B. I do not want it in the rear where it is more vulnerable to a crash.
Postby Dale M. » Sun Sep 06, 2009 10:16 pm
Keep in mind propane is a heavier than "air" gas so it settles or pools in low places.... "Drain" vents (no not dish water) need to be at very bottom of enclosure...
My personal preference is "outside" though....
Dale
Dale M.
Images: 18
umm...
Postby laoutdoorsman » Sun Sep 06, 2009 11:40 pm
propane----outside, definately....absolutely....and right side up(valve on top)...just do it...
mike breaux...its pronounced "bro".....
i think i should have taken notes along the way, because ive forgotten waaaay more than i remember...
laoutdoorsman
Images: 44
Re: umm...
Postby kennyrayandersen » Mon Sep 07, 2009 7:05 pm
laoutdoorsman wrote:propane----outside, definately....absolutely....and right side up(valve on top)...just do it...
I agree – don’t fight the feeling! Plus, if you get a 10 pounder, they are kind of cute.
kennyrayandersen
Images: 38
Postby TPMcGinty » Tue Sep 08, 2009 6:56 am
I use the cheap one pound gas cylinders that you can get in any store and I keep them in the tear. I use them on a basic coleman camp stove and it works fine. I didn't want to have to run gas pipe through my tear or worry about ventilation.
Tim
TPMcGinty
Images: 146
Postby Dale M. » Tue Sep 08, 2009 9:43 am
TPMcGinty wrote:I use the cheap one pound gas cylinders that you can get in any store and I keep them in the tear. I use them on a basic coleman camp stove and it works fine. I didn't want to have to run gas pipe through my tear or worry about ventilation.
You do not run it through your tear, you run it under the dear....
Dale
Dale M.
Images: 18
Postby TPMcGinty » Wed Sep 09, 2009 6:55 am
Dale
Thanks for the correction. You still have to run it and I don't. My point is I didn't want to mess with it.
Tim
TPMcGinty
Images: 146
