type of glue for roof plywood
Postby Dick » Mon Sep 07, 2009 9:01 pm
I just started building a 5 x 10 benroy in mid Aug. Today I installed the first layer of 1/8 in baltic plywood on the roof I want to add a second layer of 1/8 but would like some advice on whether to use titebond III, a PL or even liquid nail for adhesive. Which type (or something better) do you recommend and what's the best way to spread it? Or - does the glue even need to be distributed over the entire surface?
Dick
Images: 11
Postby wannabefree » Mon Sep 07, 2009 11:08 pm
I recommend PL due to its gap filling ability. Try as hard as you like, that second layer will not want to lay down tightly against the first layer and the PL will fill the gaps.
Actually, I used epoxy on the edges and PL everywhere else. That gave me a good bond where I needed it most, while the PL ensures everything in the middle doesn't move around any.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Postby aggie79 » Tue Sep 08, 2009 8:25 am
PL premium. Spread with a disposable (plastic) v-notched trowel or make yourself one cut with pinking shears from plastic .
Postby planovet » Tue Sep 08, 2009 9:56 am
wannabefree wrote:Actually, I used epoxy on the edges and PL everywhere else.
I only used 1 layer of 1/8" ply before the aluminum but that is exactly what I did. Epoxy on the edge and PL on the spars.
ImageMark (& Cindi)
planovet
The Cat Man
Postby Mary K » Tue Sep 08, 2009 10:28 am
I used PL Glue. No problems so far!! :thumbsup:
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby aggie79 » Tue Sep 08, 2009 1:33 pm
planovet wrote:I only used 1 layer of 1/8" ply before the aluminum but that is exactly what I did. Epoxy on the edge and PL on the spars.
I'm only using one layer, also.
Postby doctor phreak » Wed Sep 16, 2009 3:48 pm
ok dumb question...what is PL......i know what titebond and liquid nail is but PL is stumping me...help......BTW this is the same way i am going to do mine 1/8" x 2 for the roof.....
doctor phreak
Postby mikeschn » Wed Sep 16, 2009 3:57 pm
Does anyone remember what Steve Frederick used?
Postby planovet » Wed Sep 16, 2009 5:01 pm
mikeschn wrote:Does anyone remember what Steve Frederick used?
I hope he doesn't mind but here is a short excerpt from his shop notes:
ImageMark (& Cindi)
planovet
The Cat Man
Postby aggie79 » Wed Sep 16, 2009 5:12 pm
doctor phreak wrote:ok dumb question...what is PL......i know what titebond and liquid nail is but PL is stumping me...help......BTW this is the same way i am going to do mine 1/8" x 2 for the roof.....
PLĀ® Premium Polyurethane Construction Adhesive
Postby Toytaco2 » Wed Sep 16, 2009 5:13 pm
Doc - They're speaking of PL Premium Construction Adhesive. I used a bunch of it in my build. It's good stuff. Here's a link:
http://www.stickwithpl.com/Products/detail.asp?PLProductID=14
Toytaco2
Images: 368
Postby doctor phreak » Wed Sep 16, 2009 10:07 pm
thanks guys ...i have seen these....is this stuff better than titebond
doctor phreak
Postby aggie79 » Thu Sep 17, 2009 12:10 pm
doctor phreak wrote:thanks guys ...i have seen these....is this stuff better than titebond
Titebond makes a heavy duty construction adhesive similar to the PL Premium. The benefit of these is that they have gap-filling properties where the Titebond III (or II) do not.
In my build, where wood/plywood are in close tolerances I have used Titebond III. In other situations, I use the PL Premium.
Postby CPlater » Thu Sep 17, 2009 4:20 pm
I've always liked T-88 epoxy for use with wood-wood bonding. A non critical 1:1 mix with decent working time.
Courtney
CPlater
