So here are the calculations for the various forms of steel. I got the information from the PDM Steel catalog:
http://www.pdmsteel.com/PDF/pdm_cat2006c.pdf They are located near me in Stockton and I will probably get my steel from them. Here are the weights:
2"X2" .120 angle - 1.652 lbs./ft.
2"X1" .120 rect. - 2.254 lbs./ft.
2"X2" .120 square - 2.940 lbs./ft.
2"X3" .120 rect. - 3.890 lbs./ft.
For a 5'X10' frame with a total of six cross members (1 front, 1 back and 4 on 24" centers) there is 50' linear feet of tubing. The three options I have had in mind are an all square tube frame, a square perimeter with angle cross and an all 2"X1" frame. You'll see that the differences in weight are pretty slight.
All square: 50' X 2.940 =
147 lbs. total
Square perimeter 30' X 2.940 = 88.2 lbs
angle cross members:
20' X 1.652 = 33 lbs. 121 lbs. total
2"X1" rectangle: 50' X 2.254 lbs.=
112.7 lbs. total
The tongue 8' 2"X3" :
31.1 lbs. will be the same regardless as will the axles, etc.
So of all these methods I am looking at a 35 lbs. difference in the basic frame weight. I know eventually every little bit adds up but this seems to small be that big of a deal. I do not plan on towing the trailer with a small car. I think I'll just go ahead with the 2"X2" square. If someone did want to make one completely out of angle it would only weigh in at 50' X 1.652 =
82 lbs. If you were towing only on asphalt with a compact 4 cylinder I can see how that would start to be attractive.
