WayneFromMo wrote:Nice set. I have an industrial Craftsman router. Do you think I might need check on it?
And nice table
I wouldn't worry about it. Mine was a cheap model.
And nice table
mikeschn wrote:Wow, that is amazing.
We called around for that kind of insulation, but nobody would talk to us. If you don't mind, how much did that set you back?
starleen2 wrote:Now talk about BEING Well insulated - I bet if moisture ever got past the exterior skin - it wouldn't make past the insulation!
WesGrimes wrote:I am so glad I looked at this. I was about to order a DIY PU foam spray kit. That is way more than I would want to tackle...
Looks great. I bet that thing will be perfect on a cold winter night.
WayneFromMo wrote::thumbsup:![]()
Thats insulation at it's best.![]()
green_eyed_diablito wrote:kudos on a very nice, quality build. the sink and range you installed are elegant and have a cool gadget factor of 10!
and the insulation! wow...aside from sealing every nook and cranny from the elements, it will be nice and quiet inside your rig.
-miguel
Wig wrote:I'm gonna make a perdition that it was not cheap.two guy's with a truck and product for 5 hours = at least a thousand bucks.
Wig wrote:...plus they had all the correct tool including on of those sweet saws.
aggie79 wrote:Very nice, Bill! Ranks 10 out of 10 on the cool factor scale.![]()
I guess you got this done "under cover" before the HOA enforcers came around.
Have you decided how you are going to finish the exterior?
