Dean_A's Build--FINISHED!!!
Postby Dean_A » Tue Sep 29, 2009 7:34 pm
SIXTOTWO wrote:
Dean_A wrote:
Miriam C. wrote::applause: :applause: :thumbsup:
Way cool. Can you tell me about the hatch supports or where I can get detailed information? I might have to change my plan. 8)
I think you will at least be campable by July. :applause:
Miriam, I got the hatch supports through Austin Hardware. I like the low-tech nature of these props vs. the gas lifts. I did have to do some modification to these though. Shortened them up and removed one of the brackets. Easy stuff. They have more sizes and configurations now, but at the time I got mine, they only had one length and one type of bracket, so I had to make do. I ended up cutting mine down to about 18.5" Let me know if you want more info, or better pics.
--Dean
Hey Dean,
I'd like to see some more of those pictures on your hatch support. We're ready to put the same supports on our tear. Saw them first here on your thread and they looked like what we wanted. Ordered and received them within three days.
How did you figure out the right place to put them and how long the supports should be?? Is there some kind of formula for supporting the weight in the right place? We already took the one bracket off on each support.
Thanks so much!
Q
Image this photo helped a lot.
I'll try to take some pics and post those later. As far as the length/positioning, etc goes, I didn't use anything that could even remotely be considered a "formula" :-)
Basically, I just estimated a position that would (a) open the hatch wide enough so I didn't bump my head, and (b) cleared all the obstacles in the galley when the hatch was closed. Here's a good description of the process I used taken from another thread:
"I marked, with tape, where I wanted the props to mount when opened and compaired the given sizes. I then closed the hatch to see if I was at the closed length or longer, longer is not bad. If not I moved my marks until the two worked. I wanted the mounting points out as far as possible."
Obviously this is a lot easier if you haven't skinned your hatch yet (sadly, I didn't follow my own advice).
The mechanical hatch support are much more forgiving than then gas ones. They will hold up your hatch with ease no matter where they are positioned.
The only other thing specific to my installation is that I attached the hatch support to the galley wall using a threaded insert installed from the outside. If you need more info, feel free to PM me. I'll try to get some pics up as well.
Dean_A
Images: 55
IT IS AWSOME DEAN
Postby Chris D » Sun Oct 04, 2009 5:34 pm
You brought a tear to me eye when you spoke of the surprise for your little girl. I cant wait to build ours and take my little girl camping.
Thank Dean
Chris D
Chris D
Hi Dean,
Postby SATEAR » Sun Oct 11, 2009 10:13 pm
Just checking on where you bought the draw clamps for the hatch. I am not finding them anywhere including Lowes or HD.
Thanks,
Gabe
SATEAR
Images: 75
Re: Hi Dean,
Postby Dean_A » Sun Oct 11, 2009 10:19 pm
SATEAR wrote:Just checking on where you bought the draw clamps for the hatch. I am not finding them anywhere including Lowes or HD.
Thanks,
Gabe
I got them from McMaster-Carr:
http://www.mcmaster.com/#1807A62
They're stainless steel, but I have to warn you, they're not cheap.
Grant sells a different model that are easier on the wallet.
http://www.lilbear.teardrops.net/parts2 ... alleylatch
--Dean
Dean_A
Images: 55
Re: Great Job!
Postby SIXTOTWO » Mon Oct 12, 2009 12:28 pm
Dean_A wrote:Image
Do you have a photo of the hatch latches closed?? Also do they come in a pair or is the $30 the price for just one from McMaster?
Thanks!
Terry and Sue Landis
BUILD THREAD
******Embarassing our kids, just another quality service that we offer!******
SIXTOTWO
Images: 216
Postby Dean_A » Mon Oct 12, 2009 1:26 pm
The price from McMaster was just for one.
--Dean
Dean_A
Images: 55
Postby SIXTOTWO » Mon Oct 12, 2009 3:09 pm
I wanted to ask but forgot to in my last reply....
Why is your trim cut like that? On the bottom??
BUILD THREAD
SIXTOTWO
Images: 216
Postby Dean_A » Mon Oct 12, 2009 3:56 pm
SIXTOTWO wrote:I wanted to ask but forgot to in my last reply....
That cutout is for the fender. I hadn't attached them yet when I took that pic. If you look at the pics in my album you'll understand.
Dean_A
Images: 55
Postby SIXTOTWO » Mon Oct 12, 2009 4:18 pm
Ahhh, gotcha!!
Thanks for the extra picture! :thumbsup:
BUILD THREAD
SIXTOTWO
Images: 216
Re: Great Job!
Postby 01Sport » Tue Oct 13, 2009 11:28 am
SIXTOTWO wrote:
Dean_A wrote:Also do they come in a pair or is the $30 the price for just one from McMaster?
Thanks!
I got my latches from Grant, $15/pair. They work great.
K.C.
Teardrop Name: Golden State Teardrop
01Sport
Images: 29
