Door Hinge
Door Hinge
Postby Jmax » Tue Nov 10, 2009 10:07 pm
Has anyone tried using Hurricane Hinges on side doors? Or for any other vertical application.
Be careful of what you wish for. You just might get it. Image
Jmax
Images: 10
Postby High Desert » Tue Nov 10, 2009 10:41 pm
I can't see them working very well vertically, as the two halves slide into each other. You can put a set screw into the end of the larger section to hold it but being made of aluminum it would wear quickly with weight resting on it. Just my read on it.
Shaun
High Desert
Images: 27
Postby madjack » Wed Nov 11, 2009 12:01 am
...yep, the HH is not meant for vertical application for the reasons stated by HD...the offset aluminum piano hinge from Grant, a reg SS piano hinge or the living plastic hinge from Monroe are all much better choices.......
madjack 8)
Postby shopfabricator » Wed Nov 11, 2009 5:53 am
Note on the Plastice Living hinge.
I used the 6' Flat one on a boat project.
failed plastic hinge clicky :thumbdown:
Fell Apart in Three Months with Little Use! JMO
Gary
...materials can no longer be purchaced at quite those prices mentioned here!
shopfabricator
Images: 138
Postby madjack » Wed Nov 11, 2009 1:18 pm
Gary, I know nothing of the hinge you used and I am sorry to hear of the problems it caused you...I have been using this Monroe Living Hinge clicky ...it has been out in the sun and weather for 3 years both on the hatch and the doors and is just as strong today as the day it was installed...there are differences in everything.................
madjack 8)
Postby Ageless » Wed Nov 11, 2009 1:23 pm
The Monroe hinge is a metal bonded composite; not plastic as we know it. That's tuff stuff!!
Ageless
Postby shopfabricator » Wed Nov 11, 2009 3:43 pm
Thanks madjack for the correct Hinge and for fixing the "clicky thingy".
No mention of $?
shopfabricator
Images: 138
Postby madjack » Wed Nov 11, 2009 7:43 pm
...you havvta contact them directly for a quote...they only sell 50' rolls(or more)...at the time I bought mine, it was just over 50bux for a 50' roll...McMaster Carr sells it by the foot but you will pay just about as much for 10' from them...............
madjack 8)
Postby Ken A Hood » Wed Nov 11, 2009 7:48 pm
So-Cal also sells gallery/door hinges
http://www.socalteardrops.com/trimmolding.html
Disclaimer: I in no way resemble the avatar shown. Furthermore, I in no way have any affiliation to the Trailer Park Boys and more specifically Bubbles!
Ken A Hood
Images: 42
Postby 01Sport » Thu Nov 12, 2009 1:18 pm
Ken A Hood wrote:So-Cal also sells gallery/door hinges
Expensive but worth it.
K.C.
Teardrop Name: Golden State Teardrop
01Sport
Images: 29
Users browsing this forum: Google [Bot] and 9 guests
