Westfalia Pop Top?
Westfalia Pop Top?
Postby Nic » Wed Nov 11, 2009 11:56 pm
I have been playing with the idea of a Westfalia type of pop top on my teardrop. I'm sure it has been done. Any info? :thinking:
Im not lazy. I just hang out a lot.
Nic
Images: 169
Postby doug hodder » Thu Nov 12, 2009 12:54 am
Hey Nic...haven't seen you in a while....Are you thinking of scrapping a Westfalia for the top and using it or just building your own? Bruce Osborne did the Boxcar and he has roughly a similar set up on his pop top. He really did a wonderful job on it all. Not a soft side top, but the idea is the same. Doug
Postby Nic » Thu Nov 12, 2009 1:03 am
Hey Doug. I'm thinking about building my own for the teardrop i have now. With a wooden top and soft sides that works like the VW Westfalia. Either one that pops straight up or one that is hinged at the back near the galley hinge. :thinking:
Nic
Images: 169
Postby doug hodder » Thu Nov 12, 2009 1:13 am
Well, only you can be the judge of that. Having done a couple of trolley tops, I'd think you need to do some structural stuff to the existing roof to support the upper lifted portion and provide enough strength to a chopped roof and if it's not built in, could be a challenge. Me...I think I'd start with a new body to do it...just my opinion though. Doug
Postby Nic » Thu Nov 12, 2009 1:19 am
True true. I was thinking i would build a wood frame that ran side to side screwed into the 3/4" side walls.
Nic
Images: 169
Postby doug hodder » Thu Nov 12, 2009 1:29 am
Nic, I don't think I'd be of much help without seeing some rough sketches on what you have in mind based on what you are starting with. While I've cut out the center of my tears roofs with a trolley top, what you have in mind might not fit in with what I've done. Doug
Postby S. Heisley » Thu Nov 12, 2009 10:34 am
I'm building a 'pop top' of sorts. (MyAway...However, the lifting roof is the last part to go on. I'm just working on the sides and stationary roof now.)
If you haven't already, you might want to look in the design library, at Andrew's Compact version. :)
Postby b.bodemer » Thu Nov 12, 2009 11:32 am
Nic,
Check these guys out for the canvas:
http://busdepot.com/details/canvas.jsp
Barb
b.bodemer
Images: 328
Postby Nic » Thu Nov 12, 2009 7:19 pm
Heisley i like your pop top! I want mine about like that but soft sides. And thanks for the link Bodemer! I never thought about real VW soft sides. Hmm... i tow with a VW maybe i should look into that for sure. Or try and make up one that looks VW. OH and Doug ill try to get a sketch up to show what I'm working with. :thumbsup:
Nic
Images: 169
Postby Classic Finn » Thu Nov 12, 2009 7:40 pm
Hey Nic good to see you back. Where have ya been hiding? :lol: :thumbsup: :thumbsup:
Classic Finn
Apologies I dont have a reply to your question but sure is nice to see you here again :applause:
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Nic » Sun Nov 15, 2009 9:17 pm
Classic Finn wrote:Hey Nic good to see you back. Where have ya been hiding? :lol: :thumbsup: :thumbsup:
Classic Finn
Oh you know how it is. Busy with other things. I need to post some pix. I pulled my Teardrop to Oklahoma and back. That's one hell of a ride. 8)
Nic
Images: 169
Postby Ageless » Sun Nov 15, 2009 9:26 pm
Another source would be the old Chinook's; mounted on Toyota pickup chassis.
Ageless
Postby Nic » Sun Nov 15, 2009 9:41 pm
Hey now there ya go! I thought about the type that pop straight up like that. I could build my own soft sides real easy if i do it like that. THANKS! :thumbsup:
Nic
Images: 169
Postby Nic » Sat Nov 21, 2009 3:20 am
Ok i want something like this pop top but i want mine to go up about two feet.
Nic
Images: 169
Postby Ageless » Sat Nov 21, 2009 5:34 am
Ageless
