Help with torsion bar/Wall!
Postby SATEAR » Mon Nov 16, 2009 8:22 am
I have my sides up on my '47 Kitt rebuild, finally!
Do you all think there is enough room between my walls and the torsion bars??? I don't remember the distance when I demo'd the Kitt on 9/7. I have 1/2" right now.
Thanks,
Gabe
SATEAR
Images: 75
Postby aggie79 » Mon Nov 16, 2009 1:04 pm
Gabe - Let me issue a disclaimer first. I'm still building my first teardrop. That said, I don't think 1/2" is a problem. That is what I have.
Postby madjack » Mon Nov 16, 2009 1:11 pm
Gabe, there is very little side to side flex of the torsion arm...on my present tear, I have 1/4" per side and no problems...on our first tear there was only about a fat sheet of paper clearance and it never interfered...with a half inch you should have no worries...........
madjack 8)
Thanks for the reply!
Postby SATEAR » Mon Nov 16, 2009 3:18 pm
Thanks guys, I appreciate the help! I can rest easy on this point. I installed my spars yesterday and am painting in and out with oil based paint. It is finally starting to look like a TD :)
SATEAR
Images: 75
Postby Gage » Mon Nov 16, 2009 4:00 pm
Gabe, like Jack says, 1/2" should be fine. That's just about what I have on mine. The only problem that you may run into is the tire clearance to the tear side. With the wheels I'm using I ended up with only 1/16" clearance so I added 1 1/2" spacers to the hubs. Now no problem.
Image Image Image
Gage
Images: 28
Postby john » Tue Nov 17, 2009 7:25 pm
I had to cut away some material for the arm to swing in to get the close 1/2"
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
