This is such a basic question I'm almost embarrased to ask it. However, my trailer frame is a little different than most of the ones I've seen here.
In addition to the trailer light wires, I will also have the 12 volt wire from the battery on the tongue.
My trailer frame is welded from 2 1/4" tubing, so there is no channel into which I can insert the wires or conduit.
Shoud I:
1) Just staple the wires to the bottom of the 3/4" solid plywood floor; routing the wires under the tubular cross members?
2) Screw 1/2" PVC conduit sections to the bottom of the floor between the cross members; routing the wires under the cross members without conduit?
3) Add 2 1/4" spacers to the bottom of the floor and route the conduit the full length from the tongue to the rear of the frame.
4) Do you have a better suggestion that I haven't thought of?
I do intend to add insulation under the floor.
As always, thanks for your help!
