Should I use the free windows?
Postby BK One » Fri Nov 27, 2009 11:29 am
A good friend gave me these unused shed windows. They're made to frame into 1 1/2" framing.
Pros: They're free. They fit in my door. They've never been used. They're free.
Cons: They're a little heavy. My doors are only 1 1/8" thick. I can trim them out. They're white. I really need black or mill finish.
What would you do?
BK One
Images: 14
Postby dovaka » Fri Nov 27, 2009 11:57 am
i would probably use them and trim them out
dovaka
Images: 6
Postby Ageless » Fri Nov 27, 2009 12:02 pm
Most RV windows disassemble easy. Either use a wire wheel to remove the white or shoot them black.
Ageless
Postby cokebottle10 » Fri Nov 27, 2009 12:05 pm
You my want to look at what happers when the windows are open and you open the door. If they crank out then they may hit the side of the trailer when you open the door.
Thanks,
David.
cokebottle10
Postby Arne » Fri Nov 27, 2009 1:04 pm
That isn't really a problem... I ran a decrative rope from an eyelet in the door to one in the door frame.. they only open to 90 degrees...
given that windows cost at least $40, no doubt I'd paint them and use them.... no doubt at all.... but I repeat myself....
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby b.bodemer » Fri Nov 27, 2009 5:27 pm
If you are worried about the windows being opened and hitting the side of the trailer just add a door stop.
Free is good!!!!
Barb
b.bodemer
Images: 328
Postby RICHARD FURROW » Fri Nov 27, 2009 5:56 pm
WONDERING DO THEY HAVE TO HAVE DOT APPROVED GLASS?ANYBODY KNOW,LOOKS GREAT, HOPE YOU CAN AS FREE MAKES THEM LOK EVEN BETTER!
RICKY
RICHARD FURROW
Postby RogHodge » Fri Nov 27, 2009 5:58 pm
I’d use them- :thumbsup:
Better yet- I’ll give you my address- you send them to me- I WILL use them- and I’ll tell you how it turns out. :lol: :lol: :lol:
Free is a really good price!
My vote is to use them.
If the glass is a concern then disassemble them and pop in some lexan or other safety glass.
For those who would like to have a look I have a build journal and covet your feedback.
http://www.tnttt.com/viewtopic.php?t=33547
RogHodge
Images: 51
Re: Should I use the free windows?
Postby Jst83 » Fri Nov 27, 2009 5:58 pm
BK One wrote:Cons: They're a little heavy. My doors are only 1 1/8" thick. I can trim them out. They're white. I really need black or mill finish.
What would you do?
I'd say go for it you can always change out the doors later and put in different windows which is what I'm doing. For heavier doors go with piano hinges. I know where you can get some heavy duty ones real cheap like $5 off an old ambulance. I PM'd you
Jst83
Images: 215
