wannabefree wrote:The Paskett Case is 6 oz fiberglass and 3 coats of epoxy. 3 coats is about the minimum if you use 6 oz cloth. Cost for the material was near $400. I'm not sure that's much cheaper than aluminum and I think the time factor is much greater. If I were to do it again I would go with aluminum. Time is $.
Can anyone tell where to buy aluminum in Phoenix? Thanks
paperdoor wrote:I used 6mil Fabric and epoxy resin on my build -
The best price Ive found for the resin was at http://www.jgreer.com/ - only $170/incl shipping for 3 gallons and pumps (PUMPS ARE A MUST) and 3 gallons does the job. The owner answers the phone and gives great advice( he says he gets a call a week about Tears). The product works great ! Just a tip , the less seams , the less sanding. Oh but your going to sand.
right! paint will not hide any issues, it will magnify them..doug hodder wrote:Probably not the answer you want to hear, but I think how many coats you put on depends largely on how well you wet out/laid down the cloth initially and what you want your final finish to look like. There's no magic number on coats of material unless it starts getting like way too many. When it's as smooth as you think it should be for the finish you want, it's done. Paint won't hide any issues. Just my opinion. Doug
