Burke,
The maple leaf design and the extended length make a great impression. I like your changes. Now it is time to get started on the build (if you have a warm enough place for construction.)
mikeschn wrote:Burke,
It looks good, but you'll have a hard time bending plywood around a 9" Radius. Make that radius bigger, and you'll be much happier...
aggie79 wrote:Burke,
Shadow Catcher wrote:Having inadvertently bought a grasshopper design we found it ideal as far as increased feeling of space and additional storage. I like your design and the maple lief design. I look forward to following the build.
bve wrote:mikeschn wrote:Burke,
Thanks Mike, do you have a 'recommended' minimum radius? I'm prepared to used bendy ply if I have to - I'd like to keep that curve as tight as possible.
Burke
S. Heisley wrote:I had thought of copying an actual leaf or two from the Native California Big Leaf Maple tree onto my build....still haven't decided. Those leaves aren't as big as your planned one but are sometimes the size of a dinner plate (up to 9" across). So, obviously, I like your embellishment idea. I like your grasshopper trailer plan, too!
mikeschn wrote:bve wrote:mikeschn wrote:Burke,
Burke
I would make it at least 12".
http://www.google.com/url?sa=t&source=w ... YAVdq-G_3Q
